Old 06-29-2015, 05:56 AM   #1
AirPhil123's Avatar
1988 32.5' Airstream 325
Mono , Ontario
Exclamation Kill Switch Confusion
I've read the manual and understand what the literature says about operating the coach lights only with the kill switch on. When do I turn it off? I don't seem to grasp, totally and organically, what the kill switch is or does.
Please help! I don't want to burn out.
Phil
AirPhil123 is offline   Reply With Quote
Old 06-29-2015, 02:09 PM   #2
1985 32.5' Airstream 325
South Berwick , Maine
It disconnects the univolt converter and the DC circuit panel from the coach batteries. This is useful for storage, or if you have a 12v drain somewhere, to keep from killing your battery when not plugged into shore power. I also disconnect it when working on the converter or any 12v wiring to avoid accidental grounding of the hot wires. The newer converters are able to power 12v loads up to rated amperage without the batteries connected, so it can be off/open when on shore power.
The old univolts are known for killing batteries by overcharging them. Best thing to do is to replace it with one that has a "smart" charging profile.
Alechemist is offline   Reply With Quote
Old 07-01-2015, 07:49 AM   #3
AirPhil123's Avatar
Mono , Ontario
Thanks, a lot! Now to delve into the generator...
Old 12-30-2015, 01:13 AM   #4
CA , California
Is there a kill switch in a 1983 310?
I have not found one, but I want one.
If not where have others put them?
-Lani
LaniKai is offline   Reply With Quote
Old 12-30-2015, 05:43 AM   #5
Normally close to or in the battery tray. Mine is on the back of the battery drawer. Just a simple rotary lever.
Old 01-01-2016, 05:52 PM   #6
CA , California
My batteries are in the floor just in the door. I will keep this idea in my head as I do other things... maybe by the fuses?
Old 01-01-2016, 06:56 PM   #7
1974 Argosy 20
Kooskia , Idaho
-Lani
My '83 310 motorhome did not have any kill switch.
Old 01-02-2016, 01:23 PM   #8
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
My '89 370 has the kill switch just inside the door. The only downside to this is that you have to turn the switch off before you close the door, which of course does not allow the steps to retract.
streamquest is offline   Reply With Quote
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 01:59 PM
umbilical and kill switch boondockdad Electrical - Systems, Generators, Batteries & Solar 9 10-25-2008 04:05 PM
master kill switch Deborah V Our Community 6 09-06-2004 07:43 AM
Kill switch for electric jack ? remark83 Jacks, Stabilizers, Lifting and Leveling 9 06-24-2003 10:14 PM
