Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 02-17-2008, 07:39 PM   #43
Profile:  1960 24' Tradewind
santa barbara , California
Hello gwbaker ,
your doing a great job there ,As a proffesional mechanic /technician by trade
I can appreciate all the hard work there .And your right ,always have the donor vehical at the ready for ALL the little things you need ,and they will be many .One thing I will caution about is the use of that A/C condensor for a tranny cooler ,definately not what you want to use ,very restrictive ,and
will cause excessive pressure to build up on the inlet side of the cooler .Ive seen people use those A/C condensors and have major troubles .There is a flow rate for tranny coolers and volume tests that are used to check for restiction ,best to go get a big truck tranny cooler and use that instead .
you may want to install an auxilary electric cooling fan in front of your coolers to help with the temps ,either automatically engaged or with a dash mounted switch so you can turn the aux fan on whenever you want it .your condensor
is blocking all of the radiator in your photo ,you want the radiator to have some exposure to unobstructed airflow ,while maintaining a couple inches of space between coolers .Great project ,the engine looks right at home in there .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 02-18-2008, 04:57 AM   #44
Profile:  Currently Looking...
loveland , Ohio
tucson homesickness
Originally Posted by RUSSELL
AS a former torque converter rebuilder the suggestion of getting a low stall heavy duty torque converter is a must do item.
The second item is to make sure that your gas tank is completely dry before you put in diesel. Deisel engines do not do well with gas.
Regards from Russell in sunmny and cool Tucson Az.
Hi Russell
Sure wish I was in Tucson right now.
Spent 3 mos there in 1978,made a couple friends and am planning to settle in tucson someday I hope soon as I can't stand this climate in cinncinnati ohio area.
Anyway I am on the hunt for a motorhome to travel,live in,and to use to relocate to tucson someday.
If you see a 20 foot motorized argosy or airstream think of me.
Thanks for listening. - Flukewho-loveland,ohio.-
ps,picture a 4bt cummins in place of a 350 chev in a 20 foot argosy?
w.h.fluke sr is offline   Reply With Quote
Old 02-18-2008, 10:01 AM   #45
pwhittle's Avatar
Profile:  Alpharetta , Georgia
GW Baker,
I have a set of upgraded Henderson front springs that are rated for 5400-5900lbs. The good thing is that you no longer need the front airbags. I ordered these first but my 82 Classic needed the 4900 lb springs, so these have only been mounted used for one trip, then removed.
I will do you a deal on them.
Paul Whittle
1982 FFC with Motorhome Interior
http://shineee.whittlegroup.com
pwhittle is offline   Reply With Quote
Old 02-18-2008, 10:41 AM   #46
JimGolden's Avatar
Profile:  1977 31' Excella 500
Really cool GW. Good show!
- Jim
JimGolden is offline   Reply With Quote
Old 02-18-2008, 03:15 PM   #47
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
Originally Posted by gwbaker
4. 1991 = 160 hp/400 lbs trq. I will turn up if necessary. mileage only concern
5. I use a Honda 3000eu inverter on the back receiver hitch cargo platform when I need a genset. I run the high amp alternator and 2500 watt inverter instead of genset when air is needed enroute. diesel gensets just are too heavy, too loud and not worth the money in my opinion.
7. no cruise control thoughts yet, but they have aftermarket kits i will investigate.
also installed boost, pyrometer, trans temp and fuel press gauges.
I am very curious how this works out. I drove a Cummins for years and always considered them the best. I now have the Isuzu in my 345 and find it about the same as far as performance. I do have the later model which has the bigger blower and other improvements and I get somewhere in the neighborhood of 220-230 HP. I get as high as 16mpg, depending how fast I drive, or about 12mpg towing a car. I have enough power that I seldom notice the car. Just on hills.
If you have an Onan Genset you can convert it over to propane. That is what mine is and it works fine. Just run it off the propane tank then.
I am considering a new cruise control as mine has failed. I am saving the money for a "King Cruise" system. Bout a thousand dollars. Most of the add-ons are for gas engines. Very few for diesels. I have tried to replace the original "Dana" unit, but they have sold out and don't stock the old units anymore.
I use the "Boost" and "pyrometer" guages all the time. If you hold the Pyrometer temps too high for prolanged periods, you can really build up a lot of heat in the engine. Can't tell you if the Cummins will do the same. I do not have a Transmission Temp or Fuel Pressure guage, but they would probably be handy.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 02-18-2008, 04:33 PM   #48
Diesel Phil's Avatar
Profile:  Mountain Home , Idaho
Pyro
Hi, GW, Cooperhawk, and fellow diesel fanatics! I have a 12V in my 36' Classic D/P. After I put a fuel plate in the pump, I had to adjust the star wheel for less fuel because of high pyro readings and billowing black smoke on accelleration. It doesn't smoke as bad now, and the pyro never gets much over 1200. In fact, on our trip thru the White Mountains in Arizona, at an elevation of 9300 feet msl I could get 26psi boost and stay under 1200 on the pyro. With what I now know, the fuel plate was probably a waste of money. Last year, driving along Lake Roosevelt, where it was 114 degrees, I saw the coolant hot light for the first time.
So, besides an interior remodel, the 2 mechanical projects I can sneak in, under my wife's radar, are a radiator mister and an engine oil cooler. All in all, I like the 12 valve just fine.
My mileage runs right at 10mpg towing a 4000lb jeep and 12, empty. Regards, have fun. Diesel Phil and Sam
Diesel Phil is offline   Reply With Quote
Old 02-18-2008, 05:17 PM   #49
gwbaker's Avatar
Profile:  saluda , Virginia
Thanks for the info, Scott
Originally Posted by scottanlily
Hello gwbaker ,
Scott,
I took your advise and got rid of the condensor. I didn't think there was such an issue with the pressure and all that. But I did some research and you're definitely right. My setup was too restrictive. I just ordered a tranny cooler (plate style) rated for 28k lbs. Its 11"x11". I also just ordered 2 16" electric fans that push over 3000CFM each. That mechanical fan was too far away and the shroud was not even close to lining up. Not even the right size.
1979 AIRSTREAM EXCELLA / DRIVER CONTROLLED AIRBAGS IN REAR / BUFFED / HEAT DISSIPATING WHITE PAINTED ROOF / 2500 WATT INVERTER / KUBOTA DIESEL 5.5KW GENSET / ((((CUMMINS)))) TURBO DIESEL / 14CM TURBO HOUSING WITH PACBRAKE EXHAUST BRAKE / 4" EXHAUST WITH 5" EXAHAUST TIP / 16 MPG
gwbaker is offline   Reply With Quote
Old 02-18-2008, 05:24 PM   #50
gwbaker's Avatar
Springs
Originally Posted by pwhittle
GW Baker,
Paul Whittle
Paul,
What springs do I have now? Are these 5400-5900 what I need? I am definitely interested. How easy are they to swap out? Jack it up and compress the springs and getem outta there?
Greg
Old 02-18-2008, 05:30 PM   #51
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
Quite an endevor. Very nice work. Thanks for the posts and pics.
Jeff, Cindy and the Brittanys:
Remi and Hunter
'81 International 31'CB "Fus-a-lodge"
'03 2500HD Chevy Duramax w/improvments
WBCCI #7026 Air #17054
Old 02-19-2008, 08:22 AM   #52
The Hawk's Lair
cooperhawk's Avatar
Originally Posted by Diesel Phil
Hi, GW, Cooperhawk, and fellow diesel fanatics! I have a 12V in my 36' Classic D/P. Last year, driving along Lake Roosevelt, where it was 114 degrees, I saw the coolant hot light for the first time.
Okay, I'll admit to ignorence. What is the 12v. Cummins?
I have a hayward electric fan mounted on my rediator, but my fan clutch is now siezed. Gotta get that fixed before Spriing. I think I can get it out without a major tear down. Knuckle scraper though.
Did you know that when the fan siezes up and runs all the time, it can actually run hotter! Isuzu mechanic told me that. Saw the "HOT" light first time last summer.
AKA THE GUNNER
VFW, LEGION, NRA
Old 02-19-2008, 09:10 AM   #53
12 V cummins
Good morning! I meant to say 12 VALVE. as opposed to the later 24 valve.I googled King Cruise last night, didn't know there was such a thing, and now, I believe I need one of those, too! Would like to have a big electric fan but I talked to Flex-a-Lite and Haydan...they don't make one big enough. Maybe my next year project might be an aluminum radiator and a BIG electric fan. ???????????...GW, where did you get the big altenator you are using??? Furniture arrived yesterday, from the factory....if I don't get busy my wife won't type these notes for me! Have fun. Regards, Diesel Phil and Sam
Old 02-19-2008, 09:21 AM   #54
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
Cooperhawk - one thing I've learned when working in close quarters with the radiator is to cut a big piece of cardboard and put it over the face of the rad. It's thin enough that it should not cause much for clearance issues, saves your hands from scraping on the radiator, and saves the radiator from little dings.
Barry
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
1951 Flying Cloud 21'
1957 Pontiac Safari 2dr wagon TV
safari57 is offline   Reply With Quote
Old 02-19-2008, 09:44 AM   #55
The Hawk's Lair
cooperhawk's Avatar
Barry
Man, that's really good advice and I will surely do just that. This isn't foing to be fun as I have to do most of the work laying on top of the engine and reaching down. Need a big piece of foam to lay on top of the engine.
AKA THE GUNNER
VFW, LEGION, NRA
Old 02-19-2008, 02:34 PM   #56
Robfike's Avatar
Profile:  Speedway , Indiana
I just had to replace mine on the way to florida last month. You can take the four nuts loose that hold the fan to the clutch, then the four that hold the clutch to the water pump. Pull the clutch up and out, leaving the fan in it's little area. Just install the new clutch in reverse order. I did mine in 21 minutes on a hot engine. No big deal.
Rob
Robfike is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Pingbacks are On
Dodge Cummins Brad Hunt Tow Vehicles 33 12-19-2007 07:57 AM
Cummins Onan, Has anyone used them? DFord79 Generators & Solar Power 18 11-09-2007 09:50 PM
Bought 75th Bambi - need tow vehicle Bambi75th Member Introductions 27 03-24-2007 07:16 AM
First impressions of my new Dodge/Cummins tow vehicle idahosafari Tow Vehicles 14 04-17-2004 08:31 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
