Old 11-13-2008, 12:29 AM   #85
1989 34.5' Airstream 345
Silverton , Colorado
I'm thinkin' plumber's helper...
We, also, replaced the toilet...same leak...we kept the hand sprayer as it uses less water, and is better for...well...rinsing. The valve is prone to holding just enough water to freeze and crack, so winterizing includes bringing forth the vodka thru the sprayer...how many people can say they flush with vodka!!!
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 11-13-2008, 07:27 AM   #86
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I can!!!!!
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 11-14-2008, 01:06 AM   #87
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I sort of don't get the vodka thing. I mean, a 5th of the cheap stuff costs maybe $10 (in my area anyway). 2 gallons of the pink costs $6.00. I can do my 27' Overlander with 1 gallon. I expect the Motorhome will take almost 2 gallons to do.
We easily get into the sub zero range here in the mountains so I am unsure at what temperature a diluted vodka mix will stay liquid.
I am not sure at what point the eutectics of that mix will allow the water to freeze while still keeping the alcohol liquid and the coeficient of expansion of such a eutectic.
So I think I am going to stick with the pink stuff for now. I did see the very handy 3 way valve which will allow me to quickly flush the solution through. Nice!!!
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 11-14-2008, 08:31 AM   #88
The Hawk's Lair
cooperhawk's Avatar
Well now, here's the thing. The pink stuff leaves this AWFUL after taste. Vodka doesn't.
The pink stuff doesn't sanitize. Vodka does.
Once you bypass the water heater and drain it, it doesn't take two gallons. In fact I use five fifths and usually have a least half of one left over.
I live in Minnesoooota, and I have never had a freeze up problem.
And of course, don't forget the PARTY in the Spring! Okay, just joking. We don't actually drink the stuff. Spose we could though.
AKA THE GUNNER
VFW, LEGION, NRA
Old 11-14-2008, 08:43 AM   #89
SNIP-QUOTE"And of course, don't forget the PARTY in the Spring! Okay, just joking. We don't actually drink the stuff. Spose we could though."END QUOTE
I tried a sip...felt like I should have had a grocery cart full of plastic bags and three layers of clothes...not recommended...SAFE, but not recommended...I suppose I could try to flush it with tomato or Clamato juice, but then yer back to that stain thing...
Michael & Tracy
1989 345 Motorhome
Old 11-14-2008, 10:26 AM   #90
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
What the heck - I'll try it. I'll save the tomato juice for the spring...
Old 11-14-2008, 10:34 AM   #91
The Hawk's Lair
cooperhawk's Avatar
See, there you go. In the Spring just take a glass of tomatoe juice and hold it under the faucet and fill her up.
The thing I like the best is that it sanitzes the entire system with no after taste. Others reccommend using bleach. YECH!!!!
AKA THE GUNNER
VFW, LEGION, NRA
Old 11-14-2008, 11:22 AM   #92
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
One big bottle of the cheap vodka did the Silver Dragon. I blew out each of the lines with an aircompressor pushed onto the garden hose fill line. Then poured the vodka into the hose and blew each line until I could taste the vodka came out. Still had some of that nasty red antifreeze stuff come out in the shower hot water side with the vodka. Good thing I wasn't driving anywhere afterward. Was a little concerned about the fumes igniting inside the trailer until it aired out. Hey it will be fun dewinterizing in the spring, eh?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 11-14-2008, 12:02 PM   #93
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I am lucky enough to already have a bypass for the water heater and drain valves and a 3 way valve at the pump. All I have to do is hook up a hose and suck away...
Old 11-14-2008, 07:52 PM   #94
AWRIGHT!!! PARTY AT BUTTERCUP'S THIS...UHM...WHEN DO YOU GET SPRING...? Put two Airstreamers together, and they'll come up with a 'solution'...add more and you'll come up with...well...a rally
Michael & Tracy
1989 345 Motorhome
Old 11-14-2008, 10:23 PM   #95
Mexray's Avatar
1978 28' Ambassador
Morada , California
I winterized our Airstream with liquor,
Pumped through the pipes it was quicker.
Used a bucket instead of a shot glass,
While taking advantage of the bypass,
And when it freezes that should fix-her.
Ray & Pat; Morada, CA
Old 11-14-2008, 11:08 PM   #96
kontiki's Avatar
1989 25' Excella
San Andreas , California
Tim & Kimber
We just found this thread. Congrats on obtaining your "dream" motorhome. It sure was a nice looking Airstream when we toured it in Jackson and didn't know the touring car went with it. DG sure knows how to fix things. Hope to see you in it soon. Also hope you had a great trip to Arkansas. Jim & Ginny
kontiki is offline   Reply With Quote
Old 11-15-2008, 10:09 AM   #97
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Thanks J & G,
It is a beautiful rig. I felt a swelling of pride as I pumped 60 gallons of fuel into her (had to swipe my card 2 times).
And, did I mention that we created a special parking place for her? Yes, we had a load of rock dumped. The driver brought some really nice stuff, not that road stuff that we have on the rest of our driveway. Problem is that the fancy stuff doesn't stick together well and instead of having a nice parking spot, the moho just sinks right in - just like those emergency truck brake failure turnout spots you find on long steep hills.
We are having quite a lot of fun with this Airstream.
Old 11-16-2008, 02:36 PM   #98
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Just remember in the spring ....
It's o.k. to drink from the tap...
In small doses....
Do not be tempted to drink the Vodka from the other source.
The nice thing about South Carolina is that even if we have a freeze it will likely warm up above freezing in a few hours, that or I'm headin' for Florida!
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
My 345LE pics... swinginping General Motorhome Topics 3 03-23-2008 10:00 PM
Need help with my 345LE Engine! gypsychris Classic Motorhomes 8 03-06-2008 01:36 PM
Update from us, our 345LE is for sale... williamhenshall General Motorhome Topics 5 04-27-2003 06:46 AM
Interior re-do of 1989 345LE charles white Airstream Motorhome Forums 9 03-21-2003 04:14 PM
