Old 07-10-2010, 10:55 AM   #1
Jacking system resevoir fill ??? 86 345
OK this one has me scratching the old grey matter, the reservoir is over the back of the bell housing and start of the gearbox, easy I hear you say, just go in through the dog house lid. Hmm loads of cables and stuff firmly in the way, don't suppose they put a small trap in the floor just above it ?
Paul
moonshine is offline   Reply With Quote
Old 07-11-2010, 04:51 AM   #2
For the Hydraulic jacks?
Mine reservoir on the '84 345 is at the front behind the grill... its huge.
Old 07-11-2010, 06:07 AM   #3
Hi Keyair
I have a small reservoir infront of the radiator, but thats for the hydoboost (brakes and steering power). you are lucky I wish mine was there !
Old 07-11-2010, 11:22 AM   #4
Originally Posted by moonshine View Post
Hi Keyair
The hydraulic unit on our 310 is mounted in front of the radiator as well and one of these days I'm going to relocate it. I don't like anything sitting in front of the radiator that could block cooling air.
Of course its been on my list for three years now and it's likely to stay on the list for a few more years
Old 07-12-2010, 01:15 PM   #5
Hi Brad,
wish mine was so I could fill it !
Old 07-12-2010, 01:27 PM   #6
Hi Brad,
This is probably one of those things where the grass is always greener on the other size
Old 07-12-2010, 01:30 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If they did have a trap door, you would have to lift carpet to find, so once you have carpet up, if you don't find one, you can make one, using a marine access port, but Brad's delaying to making modifications without dire need makes a lot of sense. I'm doing that on my 30 to 50 amp change. Maybe when we spend more time using, it will make sense. How often do you need to add hydraulic fluid? Dave
Old 07-12-2010, 04:23 PM   #8
Thanks Dave, how often I have to fill it depends on how bad the leak is that I don't yet know about untill I get to fill the system and try it out !! I'm hoping it's just run low as none of the jacks work properly but they all make a small movement and then seem to stop, like it's run out of fluid.
Brad yes it always is !
'86 345 water system not used for 4+ years gowiththeflo Fresh Water Systems 3 06-22-2010 11:38 AM
Jacking up lightng Jacks, Stabilizers, Lifting and Leveling 8 04-25-2010 07:36 AM
When should we fill? myboyburt Tow Vehicles 51 07-23-2008 10:03 AM
Everybody go fill up. rebel beck Our Community 20 07-06-2006 08:24 PM
Newbie question, 345 water fill? pbnjsellers General Motorhome Topics 20 06-17-2005 04:32 PM
