Old 09-06-2014, 06:16 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Jack Antenna
I have just purchased a Jack Antenna for our 32.5 . I would like to know if I will have to make up a spacer because of the curve of the roof. Or will it fit close enough
shepherd57 is offline   Reply With Quote
Old 09-06-2014, 09:15 PM   #2
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Mine fit fine. Just sealed it good with calk. First one was dead. The replacement worked fine. Not having to stow the antenna is nice.
Air Dog is offline   Reply With Quote
Old 09-06-2014, 09:35 PM   #3
shepherd57's Avatar
Lindsay , Ontario
Thanks Air Dog I was thinking of using 2 layers of Butyl tape to make up for the curvature. Are you happy with the antenna
Old 09-07-2014, 09:39 AM   #4
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Jack Antenna
It seems to work at least as good as the crank up Winegard which was replaced because the mast and gears were beat to death by POs. The signal finder is handy. Especially with the new TVs and their channel scans when you don't even know what channel to look for.
Old 01-17-2017, 11:04 AM   #5
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
King Jack Antenna
Just completed installation of one. Used the optional base plate ($22) and recommend it. It covers all of the old holes and allows running the coax cable completely inside so none is exposed to the elements. I installed a short (12" or so) coax jumper at the antenna and ran it inside the housing then used a barrel connector to tie into the existing coax in the roof. There was plenty of slack in the old cable so I was able to get back to clean unexposed cable to crimp on the new connector.
Sitting inside a building with steel trusses, fluorescent light and a metal roof
it locks onto 23 digital channels! We are at least 30 miles from the nearest station and in a weak signal area.
One thing I did learn is that not all flat screen TVs have digital tuners. Got a digital to analog converter for one and replaced the other with a newer TV.
John Woodrow is offline   Reply With Quote
Old 01-18-2017, 04:47 AM   #6
John, the Jack antenna fit just fine on my Argosy, no curve problems at all.
JACK Digital HDTV Antenna Bigdaddy_2 Electronics & Connectivity 7 03-13-2014 01:48 AM
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
Jack for TV antenna outlet?? Help !!!! goldenlily Audio, Video & TV 4 10-03-2010 07:02 PM
antenna/cable jack lahrfarm Audio, Video & TV 2 02-12-2010 12:50 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
