Old 01-12-2016, 07:34 AM   #113
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
It"s probably about the same time with the radiator in, it"s just easier to see everything with the radiator out. Also much easier to get at everything with the left inner wheel well removed !
bobmiller1 is offline   Reply With Quote
Old 01-12-2016, 08:11 AM   #114
It is amazing how much better the access is to either side of the engine with the wheels off. I've found even just turning the wheels sometimes helps a lot.
Old 01-24-2016, 05:48 PM   #115
bobmiller1's Avatar
Re-installed my million dollar radiator ($985.00) today. Right now I put 3 gallons in it to not only check for leaks, (usually my luck) part of Murphy's Law I suppose....but also to run it next week and completely flush it out including the heater core under the couch. Installed a small ball valve 1/4" instead of the pedcock to make it easier to drain in the future. Also got a 30 inch vacuum hold on the AC system to recharge with R-12. Still working on the generator compartment and will finish up the fire suppression system soon. Purchased a new cruise control set up so alot of small things still to finish up before the motorhome get together.
Old 01-24-2016, 05:51 PM   #116
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1453679336.611374.jpg
ID:	256256Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679358.610837.jpg
ID:	256257Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679371.976080.jpg
ID:	256258Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679386.692627.jpg
ID:	256259Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679399.009483.jpg
ID:	256260Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679411.159316.jpg
ID:	256261Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679425.762692.jpg
ID:	256262Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679440.346044.jpg
ID:	256263Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679456.542517.jpg
ID:	256264Click image for larger version
Name:	ImageUploadedByAirstream Forums1453679469.711350.jpg
Old 01-24-2016, 06:07 PM   #117
WOW Is it gold plated?!
Old 01-25-2016, 07:42 AM   #118
bobmiller1's Avatar
Not Gold Plated, but weighs twice as much as it did when I dropped it off, they did a great job and did exactly what I wanted them to do. The core now fills the entire cavity front to rear in the tank area, I saw the core that was removed and the small 7/16" tubes were plugged in the lower 20% area of the core. The tubes in the new core are 5/8" and spaced farther apart. The true test will be in April....two road tests planned, 1 without the tow dolly and if that one goes well one with the dolly towing the Chevrolet Volt. Finished two off the four panels in the generator compartment last night....coming out exactly the way I want it to !
Old 01-25-2016, 07:58 AM   #119
That's an amazing difference in the radiator. It will be interesting to hear how much difference it makes in cooling.
This may sound like a dumb question about your Volt but if you were to run an extension cord from the motorhome back to the car on the tow dolly could you charge it if you had your generator running while you're driving?
Old 01-26-2016, 07:41 AM   #120
bobmiller1's Avatar
To answer the not so dumb question......yes you could use the extension cord if you really wanted too,,,,but we usually charge at the campground overnite and we're good to go on electric the next day. Regards, Bob
Old 01-26-2016, 07:49 AM   #121
Campground charging makes a lot more sense
What size charging circuit is required for the Volt?
Old 01-27-2016, 08:28 AM   #122
bobmiller1's Avatar
10 or 15 amp circuit, 120 volt, programable through the dashboard of the volt. 20 amp 220 volt if available. Full charge takes 10 hours on 120 volt or 4 hours on 220 volt.
Old 01-27-2016, 12:29 PM   #123
That's not to be for charging times. Something like the Volt wouldn't be a bad commuter vehicle for me as I drive 12 miles round trip to work and back each day.
Thanks!
Old 01-27-2016, 01:07 PM   #124
bobmiller1's Avatar
I commute 49 miles each way to my business....no gas coming to work, mostly downhill....engine runs last 5 miles going home....mostly uphill ! Lifetime MPG is 180.3 MPG ! 4 years now.
Old 01-28-2016, 08:06 AM   #125
Is there a projected cost for battery replacement and a time frame or mileage range as to when you will have to perform that task?
Old 01-28-2016, 05:28 PM   #126
bobmiller1's Avatar
Worst case senairio is $6000.00 for the battery....it's warranties for 8 years/80,000 miles. I just ordered a 2017. I beat them to death as they are a commuter car for me, it's just an expense that I deal with.
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 05:39 PM
Well Shoot I never knew !! airstreamcaravel Off Topic Forum 5 08-12-2003 11:15 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 08:18 PM
How come I never see.... Chuck Our Community 7 05-17-2003 10:55 AM
