Old 08-31-2015, 06:48 AM   #85
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I am looking for 4 of the clips that hold the wiper washer hose to the wiper arms. I broke and the others are "fagged out". Does anyone know here to get them ? This weekend we will be in Cooperstown, N.Y. for the Labor day weekend with the 325.
bobmiller1 is offline   Reply With Quote
Old 09-05-2015, 09:14 AM   #86
bobmiller1's Avatar
Resting in Cooperstown, New York for the holiday weekend ! Hot here so I will use the 50 amp service again like we did in Lancaster, PA.Click image for larger version
Name:	ImageUploadedByAirstream Forums1441462441.096394.jpg
ID:	247310Click image for larger version
Name:	ImageUploadedByAirstream Forums1441462464.710816.jpg
Old 09-05-2015, 09:17 AM   #87
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by bobmiller1 View Post
Resting in Cooperstown, New York for the holiday weekend ! Hot here so I will use the 50 amp service again like we did in Lancaster, PA.Attachment 247310Attachment 247311
Wow, Bob, how do you carry all the gear? Do you pull a small trailer?
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-05-2015, 11:37 AM   #88
bobmiller1's Avatar
When I was a kid, I watched my father pack all my mother's stuff into the trunk of the Cadillac for a two week vacation to a resort in PA. everything went...including the kitchen sink, so I learned about packing from watching him. No trailer and nothing in the aisle. All folding chairs and tables in the closets etc.
Old 09-06-2015, 02:58 PM   #89
bobmiller1's Avatar
Made my annual trip into the pool today !Click image for larger version
Name:	ImageUploadedByAirstream Forums1441569527.159475.jpg
Old 09-06-2015, 05:53 PM   #90
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Made my annual trip into the pool today !Attachment 247373
Very suitable headgear to be worn by Classic moho owners to Airstream rally meetings. I have to get one, seriously cool and functional.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-16-2015, 02:01 PM   #91
bobmiller1's Avatar
Time for phase 2 of my re-build to start. I would like to get the holding tank gauges to work again. The grey and black tank wiring came off years ago...it is taped up underneath for now. I will tackle them when I change the rear air bags on the lift this winter. My question is...I had the fresh water tank out last winter for cleaning....I disconnected the two sensors without paying attention to how they were hooked up. I did label the two blue wires front sensor and rear sensor but that was it. I am supposing that one sensor is for the auto-fill and the other sensor is for the tank gauge. I need to know where the wires attach to and I believe that I need the special foil/copper tape to conduct the AC current across the four tank probe pins. Any help would be appreciated
Old 09-25-2015, 01:31 PM   #92
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
So, your new AS name will be "Nevadun"???
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-04-2015, 08:34 AM   #93
bobmiller1's Avatar
So nice to have accomplished everything I wanted to get done this season. I want to thank all that helped me from the wipers to the wheels. This winter brings on phase 2 of my overhaul which wifi include replacement of most of the 12 volt wiring, a new inverter to change 12 volts to 110. Rebuilding of the exterior company's to stainless steel, a new upgrade from the 3-row to 4-row radiator and the addition of a seven blade fan from the 5 blade.Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965494.429139.jpg
ID:	249571Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965520.976933.jpg
ID:	249572Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965547.226234.jpg
ID:	249573Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965582.039558.jpg
ID:	249574Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965608.406796.jpg
ID:	249575Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965629.055634.jpg
ID:	249576Click image for larger version
Name:	ImageUploadedByAirstream Forums1443965656.106786.jpg
Old 10-25-2015, 04:00 PM   #94
bobmiller1's Avatar
It's a lot easier to work on the Airstream 325LE when it's 6 feet off the ground. Thanks to my professional friend Gary Trombley at Trombley's Auto, Breakabean, NY. I need to get the replacement air bags for the rear end....loosened the top two bolts and the single lower bolts today. I am not sure but I believe the Firestone bags are original and I want to change them as a preventative measure. I also need some help with the wiring on the grey and black tank sensors. The fresh water tank has two sensors and I believe that one is used for the auto-fill and one is used for the gauge itself. I peeled off what was left of the aluminum/copper tape but I still do not understand how to rewire it.Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806604.491182.jpg
ID:	250998Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806637.243268.jpg
ID:	250999Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806660.904056.jpg
ID:	251000Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806684.741039.jpg
ID:	251001Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806713.684862.jpg
ID:	251002Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806739.085664.jpg
ID:	251003Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806762.616600.jpg
ID:	251004Click image for larger version
Name:	ImageUploadedByAirstream Forums1445806791.437274.jpg
Old 10-25-2015, 05:19 PM   #95
Wow! Great pics!!
Thanks for posting them.
Old 10-25-2015, 05:31 PM   #96
1982 31' Airstream 310
Henniker , New Hampshire
Wow, nice lift!
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 10-25-2015, 08:50 PM   #97
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Ditto the lift!!! I don't even have fantasies that are that good.
streamquest is offline   Reply With Quote
Old 12-28-2015, 07:30 AM   #98
bobmiller1's Avatar
Round 2 has officially started yesterday. The nose is off, R-12 freon reclaimed, anti-freeze drained radiator removed and the original 5 blade fan off. The radiator will go to the shop next week to either be re-cored or upgraded to a four-row style. The seven blade fan off my 1979 GMC Jimmy will go on the 325. The generator will come out this Friday so I can take it to the shop and have it re-newed. While it is out I will install the sound proofing blanket and clean up the compartment. The trailer hitch will be re-worked so I can tow the family car with a tow dolly. Other items on the list will be to install a new inverter 12 volt to 110 under the oven (to limit generator use when the kids want to watch TV while driving), repairing all the holding tank (foil tape sensors), installing the new cruise control and some interior cabinet repairs. All should be done by the end of March so I can start road testing and make sure that everything is ready for the get together at Pennwood. Most importantly will have the fire-suppression system fully operational for the next trip down the road. P.S. still looking for 3 or 4 Alcoa's
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 05:39 PM
Well Shoot I never knew !! airstreamcaravel Off Topic Forum 5 08-12-2003 11:15 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 08:18 PM
How come I never see.... Chuck Our Community 7 05-17-2003 10:55 AM
