Old 05-25-2015, 11:42 AM   #71
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Great looking rig, looking even better in use!
martin300662 is offline   Reply With Quote
Old 06-01-2015, 03:40 PM   #72
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Side window track replace
Bobmiller1
I am doing side window track replacement on one of my side rear windows. Got every thing out and cleaned ready to go back in. Quite a time consuming job you are right.
What did you find was the best way to reinstall everything. I have replaced the front slider tracks and they were easy to reinstall, This looks like it could be a bear, Any help would be appreciated as me and glass are not very good friends.
shepherd57 is offline   Reply With Quote
Old 06-02-2015, 06:47 AM   #73
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Forget using the adhesive on the fuzzy schengel, it only makes a mess. But do run it all the way around 360 degrees, not done by the factory, it will hold the fixed window in place better and cut down on road noise. Replace all the gaskets as this is the only time you will be able to re-screen the screen. A good can of quality silicone will make everything go back much easier, clean weep hole track out the best you can and replace weep hole covers. All parts to do this job are available from Inland Supply.
bobmiller1 is offline   Reply With Quote
Old 06-20-2015, 03:42 PM   #74
bobmiller1's Avatar
Today I am tig welding the patch panel over the previous owners I'll attempt to cover a cob job that whoever replaced the front furnace butchered up ! Also got the last remaining two windows done...I hope I never have to do that again...well maybe when I find the 350 of my dreams...at least I can get the experience on the 325 that I need. I got the seven blade fan that I ordered to replace the original 5 blade.Click image for larger version
Name:	ImageUploadedByAirstream Forums1434832909.104030.jpg
ID:	241167Click image for larger version
Name:	ImageUploadedByAirstream Forums1434832926.533330.jpg
ID:	241168Click image for larger version
Name:	ImageUploadedByAirstream Forums1434832942.501120.jpg
ID:	241169Click image for larger version
Name:	ImageUploadedByAirstream Forums1434832962.466642.jpg
Old 06-28-2015, 04:15 PM   #75
bobmiller1's Avatar
I put two solid days in this weekend. Still trying to finish up stage 1 of three on the 325. I have no finished swapping the KVH in-motion satellite from the 390 to the 325, along with all the cables. Also replaced the transfer switch that powers the rear AC while the generator is running. Finished the 50 amp cord hook-up through the generator compartment...will try it out this weekend while we are in Cooperstown for the July 4th weekend. Tonight I am going to mount the fire suppression bottle to the frame and get the wipers going.Click image for larger version
Name:	ImageUploadedByAirstream Forums1435525923.980646.jpg
ID:	241778Click image for larger version
Name:	ImageUploadedByAirstream Forums1435525973.009895.jpg
ID:	241779Click image for larger version
Name:	ImageUploadedByAirstream Forums1435525991.990880.jpg
ID:	241780Click image for larger version
Name:	ImageUploadedByAirstream Forums1435526008.778945.jpg
ID:	241781Click image for larger version
Name:	ImageUploadedByAirstream Forums1435526036.761470.jpg
ID:	241782Click image for larger version
Name:	ImageUploadedByAirstream Forums1435526054.528975.jpg
ID:	241783Click image for larger version
Name:	ImageUploadedByAirstream Forums1435526078.545795.jpg
ID:	241784Click image for larger version
Name:	ImageUploadedByAirstream Forums1435526103.279050.jpg
Old 07-03-2015, 06:20 AM   #76
bobmiller1's Avatar
I had a slight distraction this week from my 325. I traded my 01 390XL in for the 07 396XL that Bill Thomas Camper Sales was selling...funny thing...we were there in 07 picking up our 05 34' Classic 34 S/O when he was delivering the 07 396 to the new owner. I said to myself then...someday. We will pick up the 396 in August.
Old 07-19-2015, 07:55 PM   #77
bobmiller1's Avatar
We are here in Lancaster, PA for a week, a flawless ride from home, 8 hours of driving, took all state roads at 55 MPH or less. Only a short drive on I 81. I have been so busy with work and my distraction of purchasing a 396XL from Bill Thomas that I did not have enough time to replace the wiper motor module that Kota sent me until I had to pull into a rest stop during a rain shower !! The heat is oppressive hear 94 ! I'm glad I wired the 50 amp service into the generator compartment. We are in a great campsite, but the sun beats on the 325 all day long...a must to have both AC's on 24/7. I will post pictures tomorrow. Two Saturday's from now we leave for MO. With our 390XL. To pick up the 396XL. I like driving the 325 at 55, very comfortable, decent fuel economy, she'll go 70 or better, but what's the rush, plus you don't see the fuel gauge going down. Will post fuel economy when we return, with the rebuilt carb, tune up, vacuum lines replaced and all the other work I did as of now I think it's around 7 MPG.
Old 07-20-2015, 09:59 AM   #78
bobmiller1's Avatar
Picture shows 50 amp campground power plugged into generator's new 50 amp bulkhead plug sold through Marinco, which I installed during phase 1 of the rebuild. Temps. Here in the 90's, it's nice to have both AC's being able to run 24/7 !
Name:   ImageUploadedByAirstream Forums1437404282.205427.jpg
Name:   ImageUploadedByAirstream Forums1437404318.093444.jpg
Name:   ImageUploadedByAirstream Forums1437404342.742552.jpg
Name:   ImageUploadedByAirstream Forums1437404361.460440.jpg
Old 07-28-2015, 08:10 PM   #79
bobmiller1's Avatar
We got back from our trip to Lancaster ! Awesome performance avg. 7.9 MPG W/generator running, got the DirectV working with the KVH in-motion satellite system that I had on the 390XL. Only two overheats on the trip...less than I expected, one going down, one coming home. In October will pull the nose off AGAIN, take the three row out put the four row in, also got the new seven blade fan that I wanted to replace the five blade. Well, off to MO. This Sat. To trade in the 390 and pick up the 396....more later.
Old 08-23-2015, 08:53 AM   #80
bobmiller1's Avatar
This coming weekend 8/29, I will be finishing the installation of the fire suppression system. I strongly suggest this add-on for anybody wishing to protect there motorhome. The plan is to install 4 heads, refrigerator, generator, and 2 on the engine. I will post the pictures next Sunday 8/30.
Old 08-23-2015, 09:32 AM   #81
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Look forward to any information of the fire suppression system! Also, Can you post the wiring details on your 50 amp conversion. I plan on doing both this fall/winter. I want to try and get the 50 amp done in September....
Thanks!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 08-26-2015, 05:36 PM   #82
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Bob, did you notice on the home page, recent photo the two wrecked coaches? The Legacy looks like it has aluminum wheels on it. Their in Tennessee, only four though.
But I have two I could part with.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 08-29-2015, 06:05 PM   #83
bobmiller1's Avatar
The fire suppression system is going to take longer than expected...it has to be done right, and good enough will not work for me. Today I finished the generator compartment and the supply line going to the refrigerator compartment. I installed an isolation valve so I can remove the tank without draining the system. Location of the sprinkler heads is also very important.Click image for larger version
Name:	ImageUploadedByAirstream Forums1440889295.302510.jpg
ID:	246724Click image for larger version
Name:	ImageUploadedByAirstream Forums1440889313.399237.jpg
ID:	246725Click image for larger version
Name:	ImageUploadedByAirstream Forums1440889331.965934.jpg
ID:	246726Click image for larger version
Name:	ImageUploadedByAirstream Forums1440889348.182222.jpg
ID:	246727Click image for larger version
Name:	ImageUploadedByAirstream Forums1440889376.332730.jpg
ID:	246728. I am also finishing the patch work on the front furnace exhaust port...another time consuming job, but it is coming out the way I want it toClick image for larger version
Name:	ImageUploadedByAirstream Forums1440889488.302109.jpg
ID:	246729Click image for larger version
Name:	ImageUploadedByAirstream Forums1440889508.599795.jpg
Old 08-29-2015, 06:44 PM   #84
wxbuoy's Avatar
Sweet. Great work!
Dave and Felicia
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 05:39 PM
Well Shoot I never knew !! airstreamcaravel Off Topic Forum 5 08-12-2003 11:15 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 08:18 PM
How come I never see.... Chuck Our Community 7 05-17-2003 10:55 AM
