Old 03-28-2015, 07:29 PM   #43
1982 28' Airstream 280
Redwood City , California
Keep up the great work Bob!
dadstoy is offline   Reply With Quote
Old 03-29-2015, 06:30 AM   #44
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Name:	ImageUploadedByAirstream Forums1427632089.141912.jpg
ID:	235116Click image for larger version
Name:	ImageUploadedByAirstream Forums1427632102.125306.jpg
ID:	235117Click image for larger version
Name:	ImageUploadedByAirstream Forums1427632120.524934.jpg
ID:	235118Click image for larger version
Name:	ImageUploadedByAirstream Forums1427632153.340943.jpg
ID:	235119Click image for larger version
Name:	ImageUploadedByAirstream Forums1427632167.807853.jpg
ID:	235120Click image for larger version
Name:	ImageUploadedByAirstream Forums1427632197.324207.jpg
bobmiller1 is offline   Reply With Quote
Old 03-29-2015, 02:16 PM   #45
bobmiller1's Avatar
Finished the roof grey water tank vent re-screening, rear bedroom TV, HDMI cable, RG6 cable installation, installed a new blue-ray 3D player in the rear also, ran the cables through the roof into the overhead wardrobe cabinet, going to tackle the in-motion satellite and roof horns tonight.Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660024.512658.jpg
ID:	235130Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660041.529434.jpg
ID:	235131Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660054.462667.jpg
ID:	235132Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660065.595913.jpg
ID:	235133Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660081.429181.jpg
ID:	235134Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660097.814108.jpg
ID:	235135Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660110.928985.jpg
ID:	235136Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660120.479236.jpg
ID:	235137Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660147.162635.jpg
ID:	235138Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660160.929188.jpg
ID:	235139Click image for larger version
Name:	ImageUploadedByAirstream Forums1427660172.546036.jpg
Old 03-30-2015, 03:36 PM   #46
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
You are kicking some serious tail on that rig.
mayco is offline   Reply With Quote
Old 04-01-2015, 05:34 PM   #47
bobmiller1's Avatar
I need a distraction from the windows for a couple of days, so I am planning next winters projects. We are going to travel quite a bit this summer in both the 325LE, and the 34 Classic S/O. I am planning various upgrades to the 325 including washer/dryer ( I already plumbed for it) dishwasher, under the microwave, new 2000 watt inverter under the oven. The 390XL is going up for sale, only 13,000 miles on it...like the Classic better. I really want a 345,350 or 370. I look once a week on various websites. I am also planning a rear end gear swap for the Dana 80, rather than go with a gear vendor overdrive or a TH700R4 I am thinking of replacing the stock 4.63 gears with 4.11 or 3.73's. I'm running about 3240 RPM @ 65 MPH. 4.11 should run around 2900 and 3.73's should run around 2600...might be to low. Has anybody done a rear end gear swap ???
Old 04-01-2015, 06:08 PM   #48
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Why not put in an Allison 5 or 6 speed
shepherd57 is offline   Reply With Quote
Old 04-01-2015, 06:43 PM   #49
bobmiller1's Avatar
I want to stay away from electronic controls.
Old 04-06-2015, 07:19 AM   #50
bobmiller1's Avatar
This last weekend was not very productive. I was only able to finish the front passenger sliding window. Although it is completely done including the smaller weep hole covers, it is apparent to me that finishing the other right side windows is going to push this stage of restoration into May. Unless I can figure how to do this in a more timely fashion the left side windows are going to have to wait until next winter. The trim replacement of the windows is so far the most labor intensive job I have done other than the water pump. During my breaks I was able to replace the lighted license plate holder, remove and clean all the taillight/back-up lenses, replace one scarelight lense on the port side that was all melted. Still working on the door hinges, replacing all interior hinge hardware as well (6 bolts/washers/lock washers/nuts) I replaced the original doorbell with a new two-tone doorbell, the original was two-tone but one coil was burnt out.
Old 04-06-2015, 07:24 AM   #51
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1428326404.722931.jpg
ID:	235701Click image for larger version
Name:	ImageUploadedByAirstream Forums1428326418.288458.jpg
ID:	235702Click image for larger version
Name:	ImageUploadedByAirstream Forums1428326434.038485.jpg
ID:	235703Click image for larger version
Name:	ImageUploadedByAirstream Forums1428326644.972307.jpg
Old 04-10-2015, 03:47 PM   #52
CA , California
I enjoy following your progress and an not looking forward to doing all our window seals soon. Any more helpful hints and advice on those?
LaniKai is offline   Reply With Quote
Old 04-12-2015, 10:27 PM   #53
bobmiller1's Avatar
Well today is Sunday April 12, I finished 3 of the 10 windows. If anyone has done a complete window trim replacement they know what is involved. Extremely time consuming ! In between the windows I finished 4 of the 6 door hinge bolts. I also mounted the new air reel into the right rear storage compartment. Next Sunday I really want to get it out of the shop and pressure wash it. I have a few other things on my list to finish before our camping season starts and I already have a major list for upgrades during next winter. I will try to finish the rest of the windows before Memorial Day weekend but it is going to have to be one at a time.Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899003.516510.jpg
ID:	236177Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899076.099877.jpg
ID:	236178Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899090.150504.jpg
ID:	236179Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899102.349255.jpg
ID:	236180Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899137.315491.jpg
ID:	236181Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899153.048746.jpg
ID:	236182Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899167.965465.jpg
ID:	236183Click image for larger version
Name:	ImageUploadedByAirstream Forums1428899183.082599.jpg
Old 04-14-2015, 06:09 PM   #54
bobmiller1's Avatar
Jeeez !!!!! After seeing what happened to Mayco going to CO. Makes me wonder....kind of creepy ! I think I'm going to order those Moog ball joints and do all 4. I still think there is more to that story but time will tell.
Old 04-14-2015, 07:21 PM   #55
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Yep, it has me paranoid too.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 04-27-2015, 06:48 PM   #56
bobmiller1's Avatar
So as you guys were enjoying your rendezvous remember I was STILL working on my windows. Three weekends left till Memorial Day weekend...kick off for the summer for us... No heavy work scheduled for the summer. Still have to get a good road test under my belt... I don't want the first camping weekend to be it. Driver's sliding window done as is the right rear bedroom slider. Also took a break between windows to re-wire and re-lense the porch light. And P.S. Thanks for the idea !Click image for larger version
Name:	ImageUploadedByAirstream Forums1430181999.962825.jpg
ID:	237215Click image for larger version
Name:	ImageUploadedByAirstream Forums1430182012.628868.jpg
ID:	237216Click image for larger version
Name:	ImageUploadedByAirstream Forums1430182028.562524.jpg
ID:	237217Click image for larger version
Name:	ImageUploadedByAirstream Forums1430182043.745808.jpg
ID:	237218Click image for larger version
Name:	ImageUploadedByAirstream Forums1430182056.278625.jpg
ID:	237219Click image for larger version
Name:	ImageUploadedByAirstream Forums1430182067.429614.jpg
ID:	237220Click image for larger version
Name:	ImageUploadedByAirstream Forums1430182081.778771.jpg
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 04:39 PM
Well Shoot I never knew !! airstreamcaravel Off Topic Forum 5 08-12-2003 10:15 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 07:18 PM
How come I never see.... Chuck Our Community 7 05-17-2003 09:55 AM
