Old 01-26-2015, 06:25 PM   #15
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Beautiful work! Makes me think about upgrading my hoses.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 02-02-2015, 04:55 AM   #16
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I got the carburator back ! New gasket, about an hour to figure out where the vacuum lines went, thank god for the original vacuum hose diagram on the side of the air cleaner, cranked it over and varoommmm ! Factory high RPM 1900 , choke off 700, thermostat opened, topped off antifreeze, no leaks, I am a happy camper. I replaced the new R-12 expansion valve that I broke during installation (DAMM), no leaks, and is holding 30" of vacuum, I will charge AC, set timing, and do base idle adjustments next weekend. Waiting for new spark plug wire holders to come from Rock Auto, then new front tires on, take it out of the shop, turn it around and bring it back in. February projects include rear drive axle overhaul/brakes, tag axle overhaul/brakes, rear shocks, shower drain, RG6 cable install, in-motion satellite install, entry door overhaul, hinges, oh....I also found a broken dash heater control cable yesterday ! It's never done.....Click image for larger version
Name:	ImageUploadedByAirstream Forums1422877997.607358.jpg
ID:	231531Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878013.622988.jpg
ID:	231532Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878028.906261.jpg
ID:	231533Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878040.606288.jpg
ID:	231534Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878053.506195.jpg
ID:	231535Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878064.689276.jpg
ID:	231536Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878079.172753.jpg
ID:	231537Click image for larger version
Name:	ImageUploadedByAirstream Forums1422878106.206321.jpg
bobmiller1 is offline   Reply With Quote
Old 02-03-2015, 07:03 PM   #17
bobmiller1's Avatar
Am I wrong in thinking that the heater/AC controls are a Chrysler product ??? Need to obtain a new heater control cable, from the dashboard climate control unit to the heater control valve under the right side of the hood. 65" long to be exact...one end is broken off. There is a seven digit part number on the cable casing (0483177). Any help would be appreciated.
Old 02-03-2015, 08:08 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When it's done, you will be Happy Man...
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-03-2015, 08:17 PM   #19
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
http://www.google.com/aclk?sa=l&ai=C...ll-cables.html
mayco is offline   Reply With Quote
Old 02-06-2015, 06:30 AM   #20
bobmiller1's Avatar
So now I am waiting for parts, the water system is shut down until i get the replacement faucet from Faucet Direct for the bathroom. The front end is still jacked up waiting for replacement air lines for the front coil spring air bags. I'm going to change the oil again anyway before I let it down, still have to grease the front end and replace the original spark plug wire looms before I let it down. Temperature here is now minus 8 degrees so I am definitely glad I am inside. Purchased new electric roof horns to replace the corroded ? original ones, new spot/search light installed...came with a neat wireless remote control so the wife can use it while we are hunting down our campsite.....seeing that we always seem to arrive at our destination after the sun sets...why is that ??? My hopes for Sunday is to get it out of the shop turn it around bring it back in and get started on the rear end.....more later
Old 02-08-2015, 05:33 PM   #21
bobmiller1's Avatar
So I lost about 1/2 of my 30lb. R-12 freon tank due to a faulty CHINESEIUM valve on the disposable cylinder and yes, it was shut off. Needless to say I found the bad heater control valve cable and repaired it...a new one is impossible to find. To my amazement after charging approximately 3 1/2 lbs. of R-12 the AC system works incredibly well. I took the cover off the interior heater core/evaporator core housing and cleaned that area up. With the climate control vacuum lines now all repaired everything appears to be in working order. I adjusted the base idle mixture screws at set the ignition timing to spec. All factory spark plug wire holders are now new and installed. I greased the front end and the tires are back on. Next weekend I will pull it out of the shop, turn it around Nd start on the rear end. I am also going to replace the rear main oil seal in April. It appears to be a two piece seal which requires removal of the oil pan.Click image for larger version
Name:	ImageUploadedByAirstream Forums1423441970.564799.jpg
ID:	231973Click image for larger version
Name:	ImageUploadedByAirstream Forums1423441983.980601.jpg
ID:	231974Click image for larger version
Name:	ImageUploadedByAirstream Forums1423442003.147341.jpg
Old 02-08-2015, 06:02 PM   #22
2015 16' Sport
ottawa (greely) , Ontario
Looks good ,I remember rebuilding two to three carburetors a day use to love doing those quadrajet carbs they were the easiest to rebuild. Only thing you might consider replacing is your inline fuel filter clamps they don't look like fuel line clamps as they can eventually cut the fuel line and lead to leaks, the fuel line clamps have a rolled edge.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 02-09-2015, 05:23 AM   #23
bobmiller1's Avatar
Yeah, Thanks Don, unfortunitly the fuel line is 1/2" and they don't make those rolled edge or as we call T-Bone clamps in that large of a size, being that the fuel filter is on the suction side with the exception of the factory 3 PSI fuel pump in the rear I don"t think we will have a problem there Got the under couch heater duct work all finished last night as well. And what about that doorbell ??? Can that be replaced with a regular one from a house??? Before I put the drawer back in under the couch I'm going to do some research on that. And last, but not least replaced the stove/oven vent as well !
Old 02-09-2015, 05:24 AM   #24
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1423484625.411874.jpg
ID:	232031Click image for larger version
Name:	ImageUploadedByAirstream Forums1423484650.679385.jpg
ID:	232032Click image for larger version
Name:	ImageUploadedByAirstream Forums1423484668.345371.jpg
Old 02-16-2015, 05:44 AM   #25
bobmiller1's Avatar
I planned on doing the tag axle shocks and rear brakes as well, but I did not expect to find the magnet wires broken...going to go with complete new self-adjusting ones. Also starting to replace all window gaskets and seals. Finished up the bathroom plumbing and sink as well. I am really hoping to make it to Colorado for the MOTORHOME get together but I think I am not going to be ready in time. I already have started a project list for next year...rebuild battery box, all slide out storage compartments, and full body strip/repaint.Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090570.936412.jpg
ID:	232520Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090590.601231.jpg
ID:	232521Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090614.051523.jpg
ID:	232522Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090643.334775.jpg
ID:	232523Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090662.768314.jpg
ID:	232524Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090671.918125.jpg
ID:	232526Click image for larger version
Name:	ImageUploadedByAirstream Forums1424090694.034581.jpg
Old 02-25-2015, 04:49 PM   #26
bobmiller1's Avatar
OK, a little help needed...looking for a source to purchase rear suspension air bags (Firestone) ???
Old 02-25-2015, 05:24 PM   #27
mayco's Avatar
AirLift or Firestone.
Old 02-25-2015, 06:09 PM   #28
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Fantastic work and write up so far. Thanks!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 04:39 PM
Well Shoot I never knew !! airstreamcaravel Off Topic Forum 5 08-12-2003 10:15 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 07:18 PM
How come I never see.... Chuck Our Community 7 05-17-2003 09:55 AM
