Old 08-09-2014, 06:37 PM   #29
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
A lot of people think I'm nuts, but after 20+ years of running down the road with Bess, I've found an oil change every 3k + fuel filter has worked well. The K & N air filter should be attended to depending on mileage and dust conditions. The upper filter (a bearcat to replace), should be changed ASAP. If you go to the 3k method, only the bottom needs replacing. Delo oil is my choice..
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-09-2014, 06:50 PM   #30
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by mayco View Post
Thanks Mike. I do believe mine is original and still operating well as far as the boost gauge readings and the power it has. But, if indeed this is as you said about being one of the first things to go on this 6bd1a ill file your info away. Is there regular maintenance to be performed on the turbo itself? Ive cleaned the K n N filter and replaced the fiber intake hose (old one was cracked bad). Is there more i should do as regular maintenance on the BAE.
While you have the K&N filter out make sure to inspect all paper pleats as I have seen a K&N filter in our rigs with no paper left resulting in all kinds of sand getting through, which sandblasted the vanes of the turbo down and left sand in the intake. If your paper is good, use K&N filter oil to apply to the pleats for added protection.
OP.....I wish you luck with whatever newer MH you get, but I personally wouldn't have made that deal. I think you will live to regret it.
Cheers
Tony
Old 08-09-2014, 07:18 PM   #31
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thanks once again Tony for your help.
mayco is offline   Reply With Quote
Old 08-09-2014, 07:32 PM   #32
Mike Leary's Avatar
Images: 11
[QUOTE=Isuzusweet;OP.....I wish you luck with whatever newer MH you get, but I personally wouldn't have made that deal. I think you will live to regret it.[/QUOTE]
I agree, poor guy, I don't wave to big box Airstreams, cause I don't see them.
The K & N problem is usually caused by someone using an air compressor to try to speed up the process of drying.
Old 08-10-2014, 04:41 AM   #33
mayco's Avatar
Are you talking about the upper fuel filter? I did go though and change all the filters, upper and Racor, oil, tranny (Allison), and cleaned and oiled the KnN. I used to have a K n N on an old thumper i rode for awhile so im familiar with that filter. Just want to make sure im not missing any.
Ive never had a vehicle that was turbo charged so i didnt know if there was some type of regular maintenence that needs to be done to the turbo itself. Sounds like just keep the air filter clean and oiled and glad i found that fiber hose on the intake. It was hard to get to, but got it done.
Old 08-10-2014, 04:52 AM   #34
Dazed and Confused
Isuzusweet's Avatar
I would have had to agree with you about the upper filter placement but a very nice and smart PO decided to relocate the filter to the lower chassis rails making it almost a breeze to change. Kinda scared me at first when I was first looking for it and only found studs!!!!
Cheers
Tony
Old 08-10-2014, 08:28 AM   #35
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Isuzu rebuild?
Cheers
Tony
The air filter on my 360 wasn't hard to get at but required removing the entire canister to replace the cartridge. Disconnecting the tube to the turbo left a opportunity to get dirt in the system. After an agonizing search I came up with a great replacement. I wrote it up in mechanics corner.
http://www.airforums.com/forums/f159/air-cleaner-retrofit-121184.html
Air Dog is offline   Reply With Quote
Old 08-10-2014, 08:37 AM   #36
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
Thanks to all who sent their good wishes. I just want to make it clear that there is NO other choice. Even junks yards would not take it unless I paid to tow it to there door step. I have absolutely no doubt that it spun a rod bearing and then the piston started hitting the cylinder head. After several minutes of this (while the mechanics played with it) it seized. The sad part is I had just paid to have oil, filter and lub done 3 miles before the failure. Did they install the filter wrong? Can't prove it. If I was back home I would take it apart myself (I worked as a mechanic many years ago) but that can't happen on the road. Not really happy about having to go to a Land Yacht.... no one stops to take a picture of them.
Tony T
2000 28' Classic TT
1994 30' Land Yacht M/H
tony6373 is offline   Reply With Quote
Old 08-10-2014, 09:46 AM   #37
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Isuzu rebuild?
That's just too much of a coincidence! Can't the mechanics check it for incorrect installation?
Old 08-10-2014, 11:45 AM   #38
Mike Leary's Avatar
Images: 11
[QUOTE=Air Dog;1494288]That's just too much of a coincidence! Can't the mechanics check it for incorrect installation?
I agree, the oil filter can be installed upside down. Now, I always check my oil pressure gauge after a LOF since blowing a turbo for this reason. I lucked out and limped back to the shop. It cost the owner a fresh turbo & labor.
Old 08-14-2014, 07:43 AM   #39
mayco's Avatar
So Tony,
Did you buy the new coach? Hope all is well.
Mayco
Old 08-14-2014, 12:18 PM   #40
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
Yes we took the plunge and bought the '94 30' LY. It drove fine on the way back to Rochester (to get our stuff out of the old 270) but it sounds like it has a cracked exhaust manifold. There is just no end to it! Seems to be a nice comfortable coach but it sure isn't a vintage A/S. No one pays any attention where we frequently had people stop us to take pictures or answer questions with the 270. On the other hand the 454 engine has gobs of power compared to the Isuzu diesel and it's quieter. The island queen bed and larger shower are nice. But how long can a fiberglass M/H last?
I'm still trying to get a few minutes with the shop owner.... he maybe avoiding me. But I know he drives a silver Audi and has to show up at the shop once in a while.
Tony T
2000 28' Classic TT
Old 08-14-2014, 09:25 PM   #41
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Tony, let's hope shop owners isn't driving something silvery that looks like a 270.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-15-2014, 07:20 AM   #42
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
I really hope you didn't get duped on this whole deal. If you are anything like me, if I'm buying it worth it's wait in gold. If I'm selling it worth it's weight in horse pucky. A search for Spartan parts turned this up.
http://www.ebay.com/itm/1992-Coachme...3D231299337313
Some people are crazy.
Isuzu Diesel fan shroud dienst1 Mechanics Corner - Engines, Transmission & More... 3 08-14-2003 09:18 PM
1981 Isuzu Diesel Engine jpurdy Mechanics Corner - Engines, Transmission & More... 10 11-30-2002 10:14 AM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
Isuzu Diesel islandvu3@cox.net Mechanics Corner - Engines, Transmission & More... 7 10-28-2002 11:53 AM
isuzu diesel islandvu3@cox.net Airstream Motorhome Forums 0 03-19-2002 09:48 PM
