Old 03-04-2010, 05:18 PM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Question Isuzu Engine Specs?
I have the Isuzu 6BD1A engine in my AS MH. The engine and chassis date to June 1983. After nearly 200k miles I need to reset the valve tappet clearances. Does anybody know what those clearances should be?
Jamie
jking is offline   Reply With Quote
Old 03-05-2010, 09:32 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
.016" both intake and exhaust cold.
Old 03-05-2010, 10:40 AM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Re- torque the rocker shaft nuts before adjusting the valve clearance. 22.4 ft-lb. I'm suprised you have not pulled the head and inspected the valves; it's overdue.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 03-08-2010, 06:35 AM   #4
Jamie
jking's Avatar
1984 31' Limited
Thank you both for valuable information. I'll proceed with this job when the weather gets a little less frigid.
Jamie
Old 03-08-2010, 06:45 AM   #5
Mike Leary's Avatar
Images: 11
I can't remember, but it seems the radio console and the doghouse has to come out to get at those front valves. Lube the water pump at the same time.
1981 Izusu Diesel Engine Specs cyclemundo Mechanics Corner - Engines, Transmission & More... 8 10-11-2008 09:10 AM
Isuzu Engine critique Versatile Mechanics Corner - Engines, Transmission & More... 25 01-20-2008 09:29 AM
isuzu engine underheating- heater not doing much sailhighc Mechanics Corner - Engines, Transmission & More... 2 12-08-2006 02:18 PM
Isuzu engine info maznblu Airstream Motorhome Forums 0 06-15-2004 10:17 AM
1981 Isuzu Diesel Engine jpurdy Mechanics Corner - Engines, Transmission & More... 10 11-30-2002 10:14 AM
