Old 07-24-2013, 08:23 AM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Question Isuzu diesel engine A/C
Can anyone supply either words or better yet pics of the engine A/C compressor mounting and belt drives as installed on the Isuzu diesel engine in a 1984 310? The PO took the thing off (and junked the parts!) and we need to put one back on.
Thanks.
J. King
email KJ4JK@ARRL.NET or leave a p.m.
jking is offline   Reply With Quote
Old 07-24-2013, 07:34 PM   #2
1995 36' Classic 36
Ludington , Michigan
Thanks.
J. King
You might want to upgrade your system. These guys can probably help you out.
http://www.myacparts.com/home.html
Kota is offline   Reply With Quote
Old 07-24-2013, 10:13 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When all fails, Contact AB&T Air Conditioning in Round Rock, Texas. They specialize in auto, bus and truck AC. I have no connection other than satisfied customer.
tel512) 388-1977
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-25-2013, 02:47 PM   #4
Jamie
jking's Avatar
1984 31' Limited
Thanks to both of you. I will definitely pursue both avenues.
Jamie
Old 07-25-2013, 03:30 PM   #5
1995 36' Classic 36
The Acme stuff they sell is the original equipment that was installed in my 95.
Old 07-25-2013, 05:02 PM   #6
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I doubt you will find much of anything available for the Isuzu. It is long out of production and the original Airstream installation was just cobbled together with some scrap iron and whatever misc. stuff they had around the shop. I tried to get a couple of pictures but it's not real easy to get to.
ID:	191723 Click image for larger version
The flat plate of the rear mount cracked so I welded it up and added a reinforcing plate. The real problem with the installation is the V-belt merely goes around the water pump pulley and the A/C compressor. Without going around the crank pulley you really have to over-tighten the alternator/water pump belts in order to drive the A/C. If not the A/C will stop the water pump and the belts just squeal. It really needs a third pulley on the crank but I think you would need the raise the A/C compressor and maybe move it in-board for the belt to clear the power steering pump or maybe an idler pulley to clear. Something to explore when I have lots of time with nothing to do.
Cheers, Dan
~ Margaret Thatcher ~
Old 07-26-2013, 07:23 PM   #7
Jamie
jking's Avatar
1984 31' Limited
Thanks a bazillion, Dan. The second pic did the trick! And your description is right on. From here it'll be easy.
Jamie
Old 07-26-2013, 09:53 PM   #8
Jamie
Glad to help. Be sure to let us know what you come up with.
Cheers, Dan
