Old 09-24-2007, 07:03 PM   #1
1968 22' Safari
1982 28' Airstream 280
Gloucester , Massachusetts
Isuzu Diesel Alternator wiring diagram
My alternator is overcharging the batteries, I need a schematic of the Alternator wiring to troubleshoot the problem. The replacement Regulator ECHVR55O IS $50 I'd rather be sure it is bad before I buy the replacement.
Does anybody have a schematic of the alternator/regulator setup on the Turbodiesel 6BD1-T equipted MH?
Mine is an 1982 280
Thanks, Art
ajheinonen is offline   Reply With Quote
Old 09-24-2007, 07:45 PM   #2
1960 24' Tradewind
santa barbara , California
I believe the regulator is inside the alternator as most all are these days .
if so ,i would pull it off and have the unit checked at an alternator rebuilder.
have you checked the alt output voltage (most likely) to see what it is ?
any external wiring to your alternator should not be able to cause it to overcharge ,usually you will have a plug with a wire for the dash light ,another for the key on only power and then one for the full time 12volt
power ,so 3 wires at one plug at the back of the alternator .Of coursed then
your main alternator output lead connection .If is overcharging the regulator
most likely is faulty and needs to be replaced ,although having it tested on
the bench to confirm never hurts either .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 09-24-2007, 08:26 PM   #3
1968 22' Safari
Thanks for the reply, but I have a seperate regulator, hence the part number listed in my first post. the alternator is outputing over 17volts which could mean a voltage sense wire is bad, but which wire is which is what I need to know. Thanks, Art
Old 09-27-2007, 09:44 PM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Spend the $50.00 and replace the regulator. I had the same thing but did not catch it before it blew out any and everything 12V which was running at the time. Seems my Alt gauge was not registering correctly. So here's your choice, $50.00 for a regulator or $2,000.00 plus to replace everything which will blow, you decide.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Isuzu diesel moisheh Mechanics Corner - Engines, Transmission & More... 5 04-15-2006 08:11 AM
Diesel engine and alternator LKappenman Airstream Motorhome Forums 12 08-16-2004 11:07 AM
Isuzu Diesel dienst1 Mechanics Corner - Engines, Transmission & More... 3 11-15-2003 01:40 PM
Isuzu Diesel islandvu3@cox.net Mechanics Corner - Engines, Transmission & More... 7 10-28-2002 11:53 AM
isuzu diesel islandvu3@cox.net Airstream Motorhome Forums 0 03-19-2002 09:48 PM
