Old 12-10-2007, 07:21 PM   #1
N2XBW's Avatar
BRADENTON, On The Picturesque and Sunny West Coast of Florida, , USA, PLANET EARTH, MILKY WAY, LOCAL GROUP, SPIRALING SLOWLY THROUGH THE UNIVERSE
Question Isn't That Just A-DOORBELL / IN SEARCH OF THE ANEMIC "TINK"
Fellow Alumilovers,
A lazy question from the recliner, beside the woodstove, on a wintry night.
The DOORBELL on my recently aquired '84 Excella 270 makes an anemic "tink" which leads me to speculate that it's not getting enough juice or that the spring is shot or clapper is misaligned.
The question: WHERE IS THE DARNED DOORBELL RINGER UNIT [I KNOW where the button is, duh!] to be found?
Thanks in advance!
John N2XBW
THE LIME HOLLOW BOYS
These aren't the droids you're looking for.
You can go about your business.
Move along.
N2XBW is offline   Reply With Quote
Old 12-10-2007, 08:44 PM   #2
1995 36' Classic 36
Ottawa , Ontario
Its under the couch in the 345
Not sure on the 270....
John
shadejo is offline   Reply With Quote
Old 12-10-2007, 09:06 PM   #3
New Borockton , Alabama
Images: 21
The anemic tink is what my 81 Excella makes. Pathetic at best and the dog won't even bark.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-15-2007, 10:00 PM   #4
Pup Rivet
ftbjc's Avatar
1984 31' Airstream310
Wichita Falls , Texas
It is under the couch and on the sidewall on my 84 310. if you have the two storage doors on the outside it is mounted between them and is easier to access from the outside than inside, good luck
Fred
84 310 Limited Motorhome
"It's when we think we know it all, that we have the most to learn"
ftbjc is offline   Reply With Quote
Old 12-16-2007, 07:26 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I'm surprised no one has suggested this...Have an assistant push the doorbell button, and follow the "tink". I know, it's too easy...
Old 12-16-2007, 09:24 AM   #6
N2XBW's Avatar
Paging Captain Obvious
So, you dare FLAUNT the Law of Lazy! You mean I have to go out there to the cold MoHo and actually DO something? Thank you Captain Obvious!
Really, of course this IS the answer.
Merry Christmas
John N2XBW
Move along.
Old 12-18-2007, 08:35 AM   #7
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
"Tink" is all any of the OEM doorbells did ... if they worked at all. We've had two - - one of each kind. Merry Christmas.
jking is offline   Reply With Quote
Old 12-18-2007, 10:18 AM   #8
gotohatteras's Avatar
Avon , North Carolina
What's wrong with knocking on the door like the rest of us miserable souls do?
DW always tells me to "take the high road"...
2006 23' Safari
2007 F350 Lariat Crew 4X4 PSD
AIR# 21875
WBCCI# 3778
Region 3, Unit 144 (Eastern North Carolina)
gotohatteras is offline   Reply With Quote
Old 12-18-2007, 10:27 AM   #9
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
My sentiments exactly
A "tink" is way more than I get out of my Globetrotter...
Dave
Fyrzowt is offline   Reply With Quote
Old 12-25-2007, 08:45 PM   #10
Joe Z's Avatar
John - You'll need to remove the streetside couch to access the doorbell. If you take a look on each side of the couch you'll see that there are two screws holding each side down. Quickest way to get these off is by placing a socket with an extension on your cordless drill. You'll probably need two people to move the couch out of the way. Once the top section of the couch is out of the way you'll be able to see behind the water tank. If my memory is correct the doorbell sits right behind the water tank alongside the interior wall of the coach - fairly close to the rear of the captains chair. Once you get in there you'll notice that Airstream simply rigged a home doorbell to run off of 12V. Joe
Joe Z is offline   Reply With Quote
Old 01-02-2008, 10:16 AM   #11
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
To avoid a new thread, and not really intending to hijack this one, has anyone added a doorbell to a non-doorbell unit? More importantly, what does the outdoor switch look like?
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 02-03-2008, 01:53 AM   #12
Chuckles's Avatar
Iwerne Minster , Dorset. UK
I didn't remove the couch, just propped it up! Lift up at the front edge, try and pull the backrest forward at the same time, or get the Miss's to do it; and prop up.
What I am surprised at is the wasted space under the false floor where the bin trays are (couch and under the bed) I plan to replace these drawers/bin trays with a "propper" drawer on runners, and at the full depth.
Any one done that?
By the way - the door bell push is a small round button type next to the entry assist handle on the door jam - hope this helps
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 02-03-2008, 07:06 AM   #13
Well Preserved
1993 21' Sovereign
I saw a new Classic 31 with a factory doorbell, in fact, several new coaches I saw had them. What I am pointing out is, you can get new ones from Airstream.
how do I search for an "exact phrase"? urbanextreme Forum Admin, News and Member Account Info 4 06-12-2006 02:19 PM
Pictures not showing up in "Most views" search ericandterry Forum Admin, News and Member Account Info 6 01-26-2004 07:20 AM
