I've removed the old sofa from the motor home and want to replace with a new sofa. The problem is that under the old sofa is the water heater! The clerance required is 14.5 inches for a new fold out bed sofa to fit. Does anyone think the water heater can be moved? Perhaps just recover the old jacknife bed/sofa?
You will have a much easier and less expensive job with recovering. A new Flexsteel sofa will fit also.
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
