Old 08-31-2006, 10:00 AM   #1
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Fallbrook , Southern California
Send a message via Yahoo to abridges01
Interior refurb on Argosy RV
Hi folks:
I originally posted this, along with several other questions, under Argosy RV's but guess that's a little too exclusive, so thought I would try a more general forum.
OK, we pick up our 'new' 1975 26' Argosy MH this weekend, and needless to say, we're pretty pumped.
There's a fair bit of work that needs to be done, though nothing terribly urgent, though the final inspection this weekend may reveal otherwise. There are some areas I know are in need of attention, and it is these which I could really benefit from you guys' experience. These areas include:
1.
Retrimming the interior: At the risk of being branded a heretic, we're not that bothered with sticking with the original wood veneer and fabric front on the lockers. Has anyone tried replacing the veneer with something a little easier on the eye such as the aluminum they use on the latest AS trailers? As you can see below, the previous owner has done a nice job with the upholstery, so we want to keep the 70's feel but replace the trim with something a little less tatty.
Thanks folks, we really appreciate any guidance or suggestions you can provide us.
Cheers,
Andrew
abridges01 is offline   Reply With Quote
Old 08-31-2006, 10:45 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The aluminum has been used ina lot of interior redo's not the easiest thing ti use though.
Check out this link, and search for more in the interior part of the restoration forums here.
http://www.airforums.com/forum...ior-17335.html
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-31-2006, 10:47 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Most people won't get as worked up over you re-doing an Argosy motor home, they are considered to be more customizable without being detrimental to the value of the coach.
Old 08-31-2006, 11:29 AM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Andrew,
I think you're safe to make it you own. Recovering or veneering with aluminum can be tricky. Do you have any close up photos of the lockers themselves?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 08-31-2006, 12:06 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I love the upholstery pattern!
Good luck with your referb!
Stephanie
Old 09-02-2006, 02:24 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Andrew!
Welcome to the Forums!
If you are considering replacing the tambour cabinet fronts (roll-up doors), the tambour material is available in several varieties including solid hardwood, wood veneers, metalic veneers, and laminate veneers. I seriously considered either polished stainless or brushed aluminum veneers for my Minuet, but decided to go with birch veneer that Arlene Fowler of Fowler Interiors stained with a pickling stain to coordinate with the factory vinyl clad wall covering.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 35 02-27-2019 07:29 PM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
