Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 08-31-2006, 10:00 AM   #1
abridges01
76 Silver Argosy
abridges01's Avatar
Profile:  Fallbrook , Southern California
Interior refurb on Argosy RV
Hi folks:
I originally posted this, along with several other questions, under Argosy RV's but guess that's a little too exclusive, so thought I would try a more general forum.
OK, we pick up our 'new' 1975 26' Argosy MH this weekend, and needless to say, we're pretty pumped.
There's a fair bit of work that needs to be done, though nothing terribly urgent, though the final inspection this weekend may reveal otherwise. There are some areas I know are in need of attention, and it is these which I could really benefit from you guys' experience. These areas include:
1.
Retrimming the interior: At the risk of being branded a heretic, we're not that bothered with sticking with the original wood veneer and fabric front on the lockers. Has anyone tried replacing the veneer with something a little easier on the eye such as the aluminum they use on the latest AS trailers? As you can see below, the previous owner has done a nice job with the upholstery, so we want to keep the 70's feel but replace the trim with something a little less tatty.
Thanks folks, we really appreciate any guidance or suggestions you can provide us.
Cheers,
Andrew
abridges01 is offline   Reply With Quote
Old 08-31-2006, 10:45 AM   #2
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
The aluminum has been used ina lot of interior redo's not the easiest thing ti use though.
Check out this link, and search for more in the interior part of the restoration forums here.
http://www.airforums.com/forum...ior-17335.html
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 08-31-2006, 10:47 AM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Most people won't get as worked up over you re-doing an Argosy motor home, they are considered to be more customizable without being detrimental to the value of the coach.
Change is inevitable, except from a vending machine
AIR#2611
Old 08-31-2006, 11:29 AM   #4
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Andrew,
I think you're safe to make it you own. Recovering or veneering with aluminum can be tricky. Do you have any close up photos of the lockers themselves?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 08-31-2006, 12:06 PM   #5
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
I love the upholstery pattern!
Good luck with your referb!
Stephanie
Our family photo blog
Old 09-02-2006, 02:24 PM   #6
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Andrew!
Welcome to the Forums!
If you are considering replacing the tambour cabinet fronts (roll-up doors), the tambour material is available in several varieties including solid hardwood, wood veneers, metalic veneers, and laminate veneers. I seriously considered either polished stainless or brushed aluminum veneers for my Minuet, but decided to go with birch veneer that Arlene Fowler of Fowler Interiors stained with a pickling stain to coordinate with the factory vinyl clad wall covering.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 7 06-19-2007 11:18 PM
Argosy Motorhome Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 09-26-2006 05:21 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
1985 Argosy MH???? 1985air345 Airstream Motorhome Forums 8 03-21-2002 07:39 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
