Old 05-13-2013, 08:39 AM   #1
1982 24' Airstream 240
Farmington , Missouri
Installing a back-up camera help, reverse on steering column of motorhome?
All the components of my back-up camera and monitor are installed on my 24' 1982 Classic. Works great with one big hang-up. From the monitor there is a lead that you hook up to the wire that becomes hot when you shift into "reverse." This activates the monitor to display your camera image. I do not want the display on all the time.
I removed the steering column cover to locate this wire I assume would be there but am stumped. On the wire harness all of the wires seem to be associated with either brakes, hazards, directional, or hot always.
Has anyone figured out where to connect the monitor wire on the steering column so that it becomes "hot" when shifting into reverse? I know I could run a wire outside of the cab, but there must be a lead I can't seem to locate.
Thanks for any info!
Timotreous is offline   Reply With Quote
Old 05-13-2013, 09:15 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Check your pm
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-13-2013, 06:17 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
You could tap into a reverse light lead?
Isuzusweet is online now   Reply With Quote
Old 05-13-2013, 06:31 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you need to find a back-up light wire; The steering column only has the mechanical linkage. You may find a wire loom going to the rear of the vehicle, for all of the tail and running lights, it should be in there.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-17-2013, 07:10 PM   #5
Well, I figured it out! Thank goodness.
So, I mistakenly thought I could locate a "reverse wire" on the steering column harness. Nope. Not quite. However, after some research and fiddling I have now become aware of the Neutral Safety switch. It is located on the backside of the steering column and serves our motorhome two functions.
It keeps the starter from engaging if you are in gear and try to start AND is the switch for the reverse lights. It does this by having a small notch of plastic that inserts into the steering column and gets rotated as you shift gears.
My switch was bad. I could start in Drive, the starter always "slipped" and my reverse lights didnt work. I
I started to try and clean it up but a new switch is only $20 from Auto Zone. They all work fine now.
All I had to do to then was tap my monitor for my back up camera into the correct lead off the Neutral safety switch and presto- it comes on automatically when I shift into reverse!
Old 05-18-2013, 06:31 AM   #6
Dazed and Confused
Isuzusweet's Avatar
Another thread bookmarked for another project. Thanks for the info.
Cheers
Tony
Old 05-20-2013, 09:14 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ats a beyouteful ting!
Channing
WBCCI# 30676
motorhome, reverse, wiring, camera
