Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 05-18-2008, 10:17 AM   #1
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
Ignition trouble
I have a '77 Argosy MH and believe I have a bad ignition switch. I can not figure out how to remove the old switch. I have unscrewed the retention faceplate but the tumbler will not release. I have tried to "pop" it out by inserting a stiff wire through the hole on the faceplate of the tumbler but nothing releases. Any tips??
77 R GO C MH is offline   Reply With Quote
Old 05-18-2008, 10:43 AM   #2
richinny's Avatar
2011 34' Classic
i think it releases when you insert the pin and turn it to acc.
anyone else have info?
Ricky
Old 05-18-2008, 11:14 AM   #3
1977 28' Argosy 28
Lincoln , Nebraska
Once again, this forum is the BEST! Rich, you were right. "insert the pin and turn it to acc." Thanks SO MUCH.
Old 05-18-2008, 11:41 AM   #4
richinny's Avatar
2011 34' Classic
Ricky
Ignition Switch For '61 Bambi Lauerman Refrigerators 2 03-16-2008 09:21 PM
Ignition relay help needed guy99 Mechanics Corner - Engines, Transmission & More... 43 02-19-2008 01:49 PM
Furnace Ignition Problem billberk Furnaces, Heaters, Fireplaces & Air Conditioning 25 01-12-2008 08:13 PM
ignition module will Classic Motorhomes 6 10-18-2006 08:48 PM
Ignition timing adjustment PeterH-350LE Mechanics Corner - Engines, Transmission & More... 9 04-20-2003 08:22 PM
