Old 10-01-2011, 08:15 AM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Ignition Switch Removal
Hello all Classic Motorhome owners.
Has anyone had to remove ignition switch? I 'tried' to pull the dash faceplate this morning. I can see now where someone mentioned that who ever was installing the dash at Jackson City, sure didn't like their job. Wow, what a mess of wires. Would at some point LOVE to get in there and make it 'cleaner', but all I need to do now is get the ignition switch removed so it can be replaces.
Any hints? Any suggestions?
Thanks, Derek
Old 10-01-2011, 08:20 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thanks, Derek
Put the key in the ignition, and turn it to the "run" position. You should find a small round hole in the key lock, put a paperclip in that hole, push in, andpull the lock out by the key. The outer locking nut will then be exposed, and you can turn it until it comes off the lock. The lock should then drop out of the instrument panel.
Old 10-01-2011, 11:36 AM   #3
crazeevw's Avatar
Hi Terry,
Thanks for the great advice. Will head out to Airstream as soon as I'm finished typing this!
Thanks again, Derek
Old 07-15-2012, 08:49 PM   #4
1988 34.5' Airstream 345
Cookeville , Tennessee
i hope this works.... i have been trying to remove mine, but didnt know the key/paperclip trick. Had me stumped. I'm removing my instrument panel as well. What a resource this forum is. Thanks Overlander63, and thanks crazeevw for asking the question.
robersonwill is offline   Reply With Quote
Old 07-16-2012, 07:04 AM   #5
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
The key/paperclip only removes the lock portion; the outer bezel with the three slots need to be turned counterclockwise to remove the whole ignition switch.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 10:03 PM
Dash Ignition Switch crazeevw Classic Motorhomes 2 09-11-2011 08:54 PM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
