Old 08-12-2006, 07:27 PM   #1
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
ICC Blink
Streamers,
I finally figured out what was the deal with my upper marker lights.
Backround....
Since we have owned our 1986 345, the upper marker lights have not worked. There were no wires going to the ICC Blink switch. My manual shows a red wire feeding all the upper lights. It says that the wire comes from the head light switch, goes to the ICC Blink switch, then to the upper lights.
The Fix....
There is no red wire. There is a cheap assed crimp type splice on the BROWN wire about 3" from the head light switch. The brown wire is the power to the lower running lights. The second wire comming off of the splice is the power for the upper lights. The crimp splice was loose, not letting power go to my upper lights. But it never went to the ICC Blink switch! So, I just cut the wire, added connectors, and plugged them into the ICC switch.
YEA!!! I now have opperating upper marker lights, and I can blink them to say thank you in night time traffic.
Robfike is offline   Reply With Quote
Old 08-12-2006, 07:52 PM   #2
RivetAddict
swebster's Avatar
Louisville , Kentucky
Rob,
Nice one! It's encouraging when someone has a "simple" wiring problem on a Classic MoHo around here. Well done!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 08-13-2006, 06:35 AM   #3
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Yes but anyone who has ever ventured behind the panel of the AS moho will tell you "it ain't simple." Chaplain Kent did the yomans work of actually redoing his dash and what a job that was.
I have some issues with my spagetti of wires and splices and weak grounds but will not tackle this until I come off the road in December.
Electricity is like plumbing but there sure are a lot of pipes back behind the dash man!
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 08-13-2006, 08:54 AM   #4
Robfike's Avatar
Speedway , Indiana
I am used to aircraft, so looking behind the dash on the AS is like wading into a rat's nest. Of course I'm also used to having a real wiring diagram as well.
Gives new meaning to "May the Force be with you"
Old 08-13-2006, 12:43 PM   #5
noiva's Avatar
Chesapeake , Virginia
Images: 46
Don't you just love the way there either isn't a diagram at all, or the one supplied has little or no relation to the actual set-up ?
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 08-13-2006, 04:29 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I call that the "not-quite-virtual-reality-diagram". And the line at the bottom of some diagrams I have seen is priceless: "wiring may differ from specification".
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Do Airstreamers Blink? guy99 On The Road... 42 01-13-2008 12:44 PM
1986 345MH Exterior lights flash Classic Motorhomes 23 06-26-2006 12:21 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
