Old 05-06-2014, 07:45 PM   #1
ASTailgate's Avatar
1981 28' Airstream 280
I thought I just needed brakes??? My first major expense
In an earlier post I said i was going to change my brakes then I decided to have the transmission pan gasket and filter changed in addition to adding new donut exhaust rings. Here's what was found during donut ring replacement. Yep not good but getting fixed. Here's more pics of todays progress.Tomorrow Im having valve cover gaskets replaced as well as ALL 1981 hoses while the transmission is out for repair. My plan was to replace both my A/C's this week but looks like thats on hold.
ASTailgate is offline   Reply With Quote
Old 05-06-2014, 07:55 PM   #2
ASTailgate's Avatar
Name:	ImageUploadedByAirstream Forums1399427641.713352.jpg
ID:	211379Click image for larger version
Name:	ImageUploadedByAirstream Forums1399427662.985057.jpg
ID:	211380Click image for larger version
Name:	ImageUploadedByAirstream Forums1399427682.020769.jpg
ID:	211381Click image for larger version
Name:	ImageUploadedByAirstream Forums1399427703.791773.jpg
Old 05-06-2014, 08:51 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Ouch!!! That hurts…..dang good reason to tell the better half why a four speed Allison suddenly showed up in the driveway.
Shiny new callipers…….How much $ if you don't mind me asking?
Cheers
Tony
Old 05-06-2014, 09:15 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would want to know what caused that case to break. The break looks new on all of it that is visible, not like a slow moving crack.
Maybe the bolts were loose?
Fwiw, that Turbo 400 shouldn't cost a lot over a thousand bucks unless it has an emergency brake hanging on the back of it...
Old 05-06-2014, 09:25 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Make that a Turbo 475 with straight cut planetaries……a little harder to find as the guys with drag cars like them a lot.
Old 05-06-2014, 10:02 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
They were used extensively and still should be reasonably common, I would hate to see the OP hit for 4K for a replacement.
Old 05-07-2014, 05:34 AM   #7
ASTailgate's Avatar
So far parts only $ 350 for L&R calipers, shoes, pr of shocks and turning the rotors. Me and my dad put those on. His mechanic friends are doing the rest. Not sure of price yet but I'll keep you up dated in prices. Will post more pics later today when I go ck in the progress.
Old 05-07-2014, 05:38 AM   #8
ASTailgate's Avatar
As far as the cause if the transmission break not sure what happened. Only thing I can gather is it's always been there. I've driven it less than 2500 once I got it back to Texas from Az and have never once hit a curb or fell into a pot hole.
Old 05-07-2014, 05:54 AM   #9
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
I would take the transmission to a competent welding shop & see if they can repair what you have.
Colin
Colin H is offline   Reply With Quote
Old 05-07-2014, 06:57 AM   #10
ASTailgate's Avatar
Colin that is exactly where it went! My dad owns a dump truck company and has his go to people. Lucky for me or not?
Old 05-11-2014, 08:35 AM   #11
ASTailgate's Avatar
Update: valve cover gaskets replaced, exhaust manifold gaskets replaced, tune up, all fluid hoses and vac hoses replaced except for fuel line which will be replaced on Monday along with power steering pump. Transmission in rebuild stage Click image for larger version
Name:	ImageUploadedByAirstream Forums1399818843.565360.jpg
Old 05-15-2014, 01:51 PM   #12
ASTailgate's Avatar
Got my rebuilt transmission back today. The weld where that crack was looks good. It's being installed today. Click image for larger version
Name:	ImageUploadedByAirstream Forums1400183334.561187.jpg
ID:	211978Click image for larger version
Name:	ImageUploadedByAirstream Forums1400183358.713360.jpg
ID:	211979Click image for larger version
Name:	ImageUploadedByAirstream Forums1400183375.690847.jpg
ID:	211980Click image for larger version
Name:	ImageUploadedByAirstream Forums1400183390.709524.jpg
ID:	211981Click image for larger version
Name:	ImageUploadedByAirstream Forums1400183405.507201.jpg
Old 05-15-2014, 02:10 PM   #13
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Amazing they can do that kind of precision welding. Always wanted to learn how to weld but never took the time. Im a retired carpenter and have worked on homes that were owned by professional welders. Their work always intrigued me.
mayco is offline   Reply With Quote
Old 05-15-2014, 09:43 PM   #14
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Any idea of what caused the case to break the first time ?
Were there bolts missing between the transmission and the engine?
Just a thought, 19.5-22.5 Isuzusweet Classic Motorhomes 7 01-18-2014 08:55 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Just when you thought you'd seen it all! balrgn Off Topic Forum 3 04-02-2005 09:14 AM
just a thought jpurdy Off Topic Forum 1 12-17-2002 10:28 AM
