Old 07-19-2018, 07:15 AM   #1
1986 34.5' Airstream 345
Londonderry , New Hampshire
I poped open my gas filler door...
Here is what I saw;
The wasps must get in through the finger slot where you open the door.
Does anyone have a solution for this?
Pete.
Air345Fly is offline   Reply With Quote
Old 07-19-2018, 07:24 AM   #2
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
wasp
I loath Wasp ! I had a bunch get in my previous SOB trailer, that came through the heater vent. I cut screen and put over them, as we never used the propane heater. Took me weeks to chase them out of the trailer. Under the tub, in the clothes hamper, in the under-sink cabinet. Annoying.
I put screen over the heater vents in the AS, and on the inside of the hot water heater cover door, and refrigerator access access panel.
Wasp are always looking for a place to build. IF you are not careful, inside the tailgate of your truck!
Have a good one
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 07-19-2018, 07:55 AM   #3
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Drive your coach more, that keeps me opening that door far too often for them to get started in there! Joking.
Cheers Richard
tevake is offline   Reply With Quote
Old 07-19-2018, 04:32 PM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Build a shop to store your Airstream in ! Regards, Bob
bobmiller1 is online now   Reply With Quote
Old 07-19-2018, 05:45 PM   #5
2007 22' International CCD
Buy a couple 'large dog' flea collars, cut them in half.
Install one half in your battery box and propane tank enclosure, and the other in the gas tank fill area. Another half goes inside the hot water heater enclosure.
No more wasps for at least 4-6 months!
Old 07-20-2018, 06:48 AM   #6
I like that idea. I will check with my wife and see how it goes.
Old 07-20-2018, 06:50 AM   #7
I have not heard of that. Sounds like a simple solution to the problem.
Old 07-20-2018, 07:21 AM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Get some killer bees as pets?
Or this little pesky rascal should do the trick.
https://en.wikipedia.org/wiki/Asian_giant_hornet
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-20-2018, 07:40 AM   #9
Cheers
Sidekick Tony
Yes, I need some of those. Where can I get some? eBay?
Pete.
Old 07-20-2018, 09:22 AM   #10
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Or put some mothballs under the cover, and when the engine is low on pep, throw one in the tank
(Kidding on in the tank, not sure if that will kill your motor)
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 07-20-2018, 06:29 PM   #11
Dazed and Confused
Isuzusweet's Avatar
Pete.
Yes, Chinese Ebay; could be a bit of trouble getting past CBP though as they could constitute a threat to national security.
Fixed my gas filler door. Air345Fly Classic Motorhomes 3 11-09-2017 11:08 AM
Gas Tank Filler & Vent Hose geodrake General Motorhome Topics 4 01-05-2011 10:42 PM
Water filler door tschat Plumbing - Systems & Fixtures 5 04-07-2008 07:08 PM
Fuel leak in the gas filler hose mrgump Airstream Motorhome Forums 5 04-04-2007 03:51 PM
Can't open filler pipe opening soulshine Fresh Water Systems 2 03-18-2007 12:08 PM
