Old 04-13-2005, 07:10 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
How are these supposed to be sealed?
My 84 310 Limited MH has two "drawer" type storage bins which are accessed from the outside. The covers look like the battery drawer, but when you pull them out there is a lockable door covering the top of the drawer.
How are these inner doors supposed to seal? When I purchased the MH there was some weather stripping on the inside of these doors but it clearly is not water tight. Does anyone know how this is supposed to be?
Also, the doors which allow access to the space below the couch from the outside don't seem to seal well either. These openings are fit with a gasket but the doors do not see to make firm contact all the way around. Any suggestions?
guy99 is offline   Reply With Quote
Old 04-14-2005, 05:50 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I don't have the drawer type storage on mine, but I can say that the ones with doors that open top down are notorious for leaking. I resealed mine with glue on weather strip from a hardware supply and it has held up better, although I still will get some minor leaks after washing or a big rain.
I also had to reseal the inside of the larger one below my water heater as it had a steady leak that dripped in there when I got the MH. Fixed the leak, then redid the floor of the storage bin and sealed it with three coats of rust preventive.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-14-2005, 11:39 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If I remember right there is a lip that stands up around the perimeter of the opening. This lip is under the lid when closed.
You could takes some modeling clay and use it to determine the clearance between he lip and the lid. Once you have that size you can source automotive trunk weatherstripping that can be slid on the lip and will have a bulb seal top. It comes in a plethora of sizes. I think Alan even posted an on line company that sells it a while back, but I don't have the link.
This should make the drawer water resistant. I do not think there is a way to make them watertight beyond welding them closed.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-18-2005, 11:38 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Restoration Specialties 814-467-9842
Sells all sorts of automotive rubber and weatherstrip. Reasonable too.
AIR #005
retired!
Old 04-19-2005, 06:51 PM   #5
guy99's Avatar
Images: 16
Thanks, Alan.
Man, they sure have a lot of neat stuff in their catalogue.
Old 07-02-2006, 08:09 PM   #6
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Guy, you need new gaskets. The door to the area under the couch should seal when the gasket is the correct one and properly installed. DO NOT use weatherstripping! It will leak. You can, however, use weatherstripping on the slideout top hatches ... get the closed-cell foam type with one sticky edge. I used 1/2 inch thick and it worked.
Jamie '84 310 Turbo Diesel
jking is offline   Reply With Quote
I'm afraid this is going to be expensive... Stefrobrts 1966-68 Caravel 236 03-06-2018 08:35 PM
1975 Argosy front window Happycampers Windows & Screens 9 11-03-2005 07:51 PM
Brake Pedal Supposed To Be HARD? fangthorpe Airstream Motorhome Forums 8 11-29-2003 01:10 PM
clearance lights not sealed? Cruiser Lights - Interior & Exterior 3 11-03-2003 03:23 PM
'95 Classic Headlights: COMPONENT or SEALED? Griffin Mechanics Corner - Engines, Transmission & More... 1 02-07-2003 12:16 AM
