Old 02-22-2015, 08:26 PM   #1
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
hood latch
Every once in awhile I see a photo of a classic with the hood hanging partway open, and mine is in danger of joining that crowd.
The hood latches have a cam that locks behind a frame piece when you spin the latch with your thumb. The cam is held onto the latch by a screw, and on one of mine the threads inside the latch have stripped.
I would like to buy new latches if I can find them, rather than trying to cut new threads into the pot metal latch. I think that this is close:
http://www.amazon.com/Camco-44323-Th...thumb+operated
But I am pretty sure that the latch body is too short, and I am not where the coach is to measure. If anybody can point me to a source or give me the length of the latch body I would appreciate it.
Waipio Rim is offline   Reply With Quote
Old 02-23-2015, 01:04 PM   #2
KB6YAF's Avatar
Olympia , Washington
I just fixed my latches. This is how......
1. unscrew the latch from the barrel.
2. Pull the center out being careful not to loose the ball bearing and spring.
3. Drill out the center hole larger and slightly smaller in order to tap for a 1/4"
by 20 thread tap
4. Tap the center with the 1/4" X 20 thread. Clean it out and replace it back
inside the barrel with the ball bearing and spring.
5. Attach the flat latch part with a new stainless steel 1/4" X 20 screw at the proper
length for the newly tapped hole. Also, use either a stainless steel lock washer
or star washer to firmly lock everything in place.
I literally just finished mine, and it is working perfectly to keep the front panel up and secure. Oh, and yes, the 7/8" replacement part you listed is not long enough.
KB6YAF is offline   Reply With Quote
Old 02-23-2015, 01:49 PM   #3
1982 28' Airstream 280
Redwood City , California
I need to do this to mine! Thanks!
by 20 thread tap
dadstoy is offline   Reply With Quote
Old 02-23-2015, 07:29 PM   #4
Waipio Rim's Avatar
Honokaa , Hawaii
Thank you KB6YAF, looks like I will be taking a tap with me next trip.
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 01:49 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 10:52 AM
Hood latch nickglase Classic Motorhomes 4 03-02-2007 06:13 PM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
Restore shine to hood and rear scotta Airstream Motorhome Forums 1 06-28-2002 08:26 AM
