Old 10-23-2006, 01:04 PM   #1
Henschen Tag Axle
I have a service manual for the tag axle air bag system. This describes the operation, lists all of the components with part numbers and has an air flow schematic diagram. Very useful for trouble shooting and service. On my trip to Alaska I had the right side tag axle fail, destroying the tire and dropping the axle and brake to within 3 inches above the ground. I rigged up a quick fix and drove 5000 miles till I was able to get it fixed. I will be happy to provide any info on the tag axle including quick fix hints and axle operation.
wa3vez@comcast.net
Howard Lefkowitz is offline   Reply With Quote
Old 10-24-2006, 01:17 AM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
I'ds like to here and see photos of the trip to Alaska!
klattu is offline   Reply With Quote
Old 10-29-2006, 04:24 PM   #3
1985 34.5' Airstream 345
Fishers , Indiana
It would be great if you would post the information into this forum so we all can save it for future needs.
Wayne Olson is offline   Reply With Quote
Old 10-29-2006, 09:39 PM   #4
Henshen Tag Axle Info.
Here is the information.
ID:	27726   Click image for larger version
Old 10-29-2006, 09:47 PM   #5
Description of Tag design
Final page of data.
Name:	System Components2.jpg
Old 05-10-2007, 01:59 PM   #6
1988 34.5' Airstream 345
CUMMING , GA
Hello Howard,
Do you know where I can get a manual for the tag? I have an '88 345 and the bags are shot. CW says they don't do that sort of work so I am in a bit of a quandary on where to go now.
wpapke is offline   Reply With Quote
Old 05-10-2007, 02:53 PM   #7
The above post is the only Manual I know of. The air bags are listed under the 1990 345 Motorhome thread. Changing the bags took a professional 7 hours and he had a pit in the garage. They are a bit of a pain since usually all of the air lines and fittings have to be replaced. You should also check your air tank to make sure it does not have any holes. If you have not regularly let the water out of the tank you will have developed rust holes. These can be fixed by a really good spot welder. I used a truck repair shop that specialized in springs, shocks and bags for everything from dump trucks to 18 wheelers. They had never done a Motor Home but they had no problems and all of the parts needed. I supplied the bags and specialized Henshen stuff. It cost me $130 and it was well worth it.
Old 05-10-2007, 06:55 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by wpapke
Hello Howard,
You should consider yourself lucky that they don't!!!
Try any large truck repair shop. A lot of over-the-road rigs use air bag suspensions and they should be very familiar with the set-up.
Old 05-12-2007, 06:49 AM   #9
90345's Avatar
1990 34.5' Airstream 345
Just discovered the right rear tag shock is leaking on my 89 / 90 345 LE.
Need to replace the pair - can anyone recommend the best brand or how to even determine the correct application ?
Appreciate the advice.
90345 is offline   Reply With Quote
Old 05-12-2007, 07:41 AM   #10
They are the same as the trailer shocks.
Old 05-12-2007, 08:11 AM   #11
90345's Avatar
Great ! Thanks for the quick reply.
Old 05-12-2007, 09:23 PM   #12
lewster's Avatar
See if you can find a set of Bilstein shocks as replacements. They are used on most of the big, air bag suspended MoHos and have a lifetime warranty. I have used them on every vehicle I have owned since 1986.
I have a set waiting to go onto my '04 Sprinter as we speak!
Old 05-15-2007, 01:38 PM   #13
CUMMING , GA
Thanks guys. I did find a truck shop to do the work.
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
what's the tag axle for? maznblu General Motorhome Topics 1 04-16-2004 07:54 PM
Henschen Axle Plant Tour Inland RV Center, In Axles 0 09-22-2002 02:04 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
