Old 02-05-2016, 07:40 AM   #1
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Help with 345 heaters!!
Hello all. I have an 1987 345 and both furnaces have stopped heating. When I turn on the thermostat the blower comes on and I can hear them click which is calling for gas but they won't ignite. The batteries are good and hot and the propane tank is full. I could sure use some help with getting them out to disassemble and clean without destroying the cabinets they are in. And then some help with what to look for once I have them out. Thanks in advance
1987_345 is offline   Reply With Quote
Old 02-05-2016, 09:19 AM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
When is the last time you had the furnaces working ???
bobmiller1 is offline   Reply With Quote
Old 02-05-2016, 10:05 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
If they both failed at once, are you sure that your propane regulator is working properly and all valves are open? Do the water heater and range work OK?
Old 02-05-2016, 11:01 AM   #4
Kenneth
1987_345's Avatar
Waxahachie , Texas
Yes the range and water heater work fine. I've had trouble with the rear heater before but usually after I turn it off and on a few times it finally works. When I tested both of them last month neither would ignite
Old 02-05-2016, 12:05 PM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Are they Suburban furnaces? If so here is a good pdf for operation and troubleshooting.
http://www.gmceast.com/technical/Nic...an_Furnace.pdf
mayco is offline   Reply With Quote
Old 02-05-2016, 12:25 PM   #6
Kenneth
1987_345's Avatar
Waxahachie , Texas
I'm not sure what brand they are. They are whatever it came with brand new. I'll look when I get home tonight. Kenneth
Old 02-05-2016, 05:24 PM   #7
mayco's Avatar
http://bryantrv.com/docs2/docs/suburban_dd_nt.pdf
This is a better link to the maintenance and trouble shooting of the Suburban NT series furnaces. If yours are original to the rig I believe they are Suburban furnaces.
Mike
Old 02-05-2016, 07:54 PM   #8
bobmiller1's Avatar
No...I do not believe they are Surburban....but are probably Hydro-Flame. An exterior picture of the exhaust outlet will prove this. The hydro-flame were useless even when new that would explain why they are no longer around. However if they are Surburban, chances are that either the battery voltage is to low or the igniters need to be changed. Regards, Bob
Old 02-06-2016, 07:51 AM   #9
Kenneth
1987_345's Avatar
Waxahachie , Texas
Ok they are both Duo-Therm furnaces
Old 02-06-2016, 08:33 AM   #10
bobmiller1's Avatar
The Duo-Therm/Hydro-Flame were junk when new....they had a problem with the burn chamber. The previous owner of my 325LE had the front one replaced with a Surburban....Took me a whole summer to Tig the exterior skin back to original after the hack job was done ! The rear furnace was not operational...I tried a complete overhaul, and finally gave up and threw it in the dumpster....I replaced it with a 30,000-50,000 Atwood. It came out real nice.
Old 02-06-2016, 04:49 PM   #11
Kenneth
1987_345's Avatar
Waxahachie , Texas
How did you get the unit out? The PO said they had never had used either of these. I've only used them 3-4 times since 2009. They look new and worked great when I had used them before. I was hoping it was an igniter or something simple
Old 02-06-2016, 05:25 PM   #12
Getting the furnaces out of a 345 could be referred to as a project from h*ll. They are installed at the factory fairly early in the construction phase so be prepared to take a bunch of stuff apart to get at them.
I parted out an 86 345 a couple of years ago and was amazed at what it took to get to the furnaces. No real consideration by Airstream for down the road maintenance.
I don't envy you on this at all
Old 02-06-2016, 09:30 PM   #13
Grosspoluter's Avatar
Franklin Park , Illinois
I repaired both heaters in my 345 about a year ago.
As I remember one was a dual therm the other was a suburban. The suburban needed a new blower motor.
The duo therm needed a igniter board and a sail switch.
I do believe the suburban was an aftermarket because the exterior exhaust port was obviously redone.
I have the paper for the igniter board it came from RV parts outlet 9620 SW. Tualatin- Sherwood rd Tualatin OR.
Phone number 503-692-6044
The description on the packing slip is a dinosaur board for duo-therm U1BS the price was $89.95
I do not remember where the blower motor or the sail switch came from.
The RV and the paperwork are 90 miles from my home where I am writing this.
As I remember at the furnaces had to be unbolted from the floor, then unwired from the RV, and the gas line disconnected.
Then they slid out of the cabinet, and then I was able to work on them on a work bench.
I do remember removing the blower motor and the sales which was quite a job, even while working on the workbench, with the unit out of the camper.
But not as hard as working on the wiring under the dashboard...
But that's another story��
I wish I could be of more help, hope I was of some help.
Grosspoluter is offline   Reply With Quote
Old 02-07-2016, 12:45 PM   #14
Kenneth
1987_345's Avatar
Waxahachie , Texas
Actually this is helpful. I got the front one out just now. Sail switch seems to be operating fine. Is the circuit board you referred to its sole function to control the igniter? I suppose that could be the trouble just from its age. All else appears brand new. I may call camping world and see if they have a way to test it. Thanks again for the info. Kenneth
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 03:38 PM
Help! Need thoughts on heaters/furnace 68 TWind Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-01-2009 08:33 PM
345 heaters pbnjsellers Classic Motorhomes 12 03-27-2005 04:18 PM
Help please with Propane heaters Earthling1 Airstream Motorhome Forums 10 11-04-2003 11:29 AM
