Old 03-21-2015, 03:38 PM   #1
Aluminated
1987 29' Airstream 290
El Cajon , California
Images: 14
Help me Please!
I have an 87 290 MH. The needle popped off the airbag pressure gauge. The gauge is sealed and has no Mfg name on it. I've been to about a dozen supply houses, auto parts stores, air shock suppliers with no luck. No one seems to know who Mfg'ed the gauges. Can someone help me with this??? The emblem looks like a "T" with a block on both sides of the 'T'.........Thanks
ericjan2 is offline   Reply With Quote
Old 03-21-2015, 03:56 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I can't off the top of my head know what size gauge you have for air. Maybe 2" in diameter? Measure your gauge face and buy a new one the same size.
Kleinn Air Horns 1021 Dash mount analog air pressure gauge - 1/4" NPT inlet
Gauges - eGauges.com
Don't panic
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 03-21-2015, 05:12 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Jeg's or Summit auto list hundreds of auto gauges. Contact them. It is moist likely a standard pressure gauge you just have to give then the range and hole diameter. 2 1/8 in. is common diameter.
2004 Excursion 4x4
Old 03-21-2015, 07:29 PM   #4
Aluminated
Images: 14
It is 2 1/8. I was able to break out the plastic face (which I found out was really glass!) and remount the needle. One problem. There are four electronic attachments on the back. Red, Black, Purple and white. Between the purple and white was a small black cylindrical resistor or capacitor ( I don't know which) which disappeared somewhere between home and all the stores I visited today! I know the black was ground and the red was load, so I hooked it back up, but now the needle doeson't move! Any ideas?
Old 03-21-2015, 08:54 PM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Hehehehe, see post #2 and #3
mayco is offline   Reply With Quote
Old 03-22-2015, 11:10 AM   #6
Dazed and Confused
Isuzusweet's Avatar
If you see on this link there is a picture showing the back of the gauge. I don't know if yours has a 1/4" or 1/8" NPT fitting but yours should look like this one.
GlowShift | Tinted 7 Color 200 PSI Mechanical Air Suspension Gauge
If not please take some pictures of the gauge that you have and post them so we can see.
OK OK I finally got off my duff and went out to the Mistress to check my gauges.....sure enough my 1983 has the same gauges. My speedo had the same T with two blocks on either side, my oil and water had the name Teleflex written in the gauge face.
Teleflex are marine quality gauges so it doesn't surprise me that Airstream used them (although I did have a VDO gauge but I'm not sure that its stock). You can contact this place if you want a Teleflex gauge, HOWEVER even they may not have a direct replacement and you will pay through the nose for it.
http://www.boatersland.com/telinst.html
Cheers
Tony
Please...Please...No Silicone Roadrunner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-24-2014 09:00 PM
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 10:33 PM
PLEASE, OH PLEASE, may I speak with the WIZARD??? WILDRTEXAS Stoves, Ovens & Microwaves 3 10-09-2009 11:27 PM
Moderators - Please... pretty please... Foiled Again Off Topic Forum 21 03-31-2006 05:29 PM
Closet Flange help! Please read and help! rocat1997 Plumbing - Systems & Fixtures 7 01-28-2006 06:40 PM
