Old 06-05-2011, 11:26 AM   #1
Sacramento , California
Exclamation Help...Batteries or what?
I winterized my 345 almost according to instruction manual. When batteries were reinstalled, the main one (and others likely) were drained. Took to town, had recharged and tested good. Reinstalled. MH will still not even begin to turn over.
Any suggestions? Charging the other two house batteries and using that switch in the glove compartment? Getting someone out here? Is this a battery problem or maybe something else?
All suggestions appreciated.
silverdream2 is offline   Reply With Quote
Old 06-05-2011, 01:02 PM   #2
1985 31' Excella
Fresno , Texas
Did you clean the terminals on the battery and cables. It it a Diesel or gas engine? Is there any noise at all?
Wsmith is offline   Reply With Quote
Old 06-05-2011, 01:16 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep...charge the batteries fully (got a charger?), Clean all the cables, including starter cable and grounds, a strong click,click sound may indicate a good charge but faulty starter, Could go on but better to start with the obvious.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-05-2011, 04:09 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
What he said.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-01-2011, 08:58 AM   #5
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Just finished a 1,300 mile trip (we took the long way) from San Antonio to Knoxville. When we were getting ready to go at our son's in San Antonio, had problems like this. Our son found the problem. The cable terminals at the batteries were good, but following the positive chassis battery cable to its other end in the back of the battery box found that the terminal had broken from too many drawer open/close cycles, and it was alternately making contact, not making contact, or shorting everything out. New terminal, and all is good.
Waipio Rim is offline   Reply With Quote
Old 12-01-2011, 09:39 AM   #6
New is Good...
PFC
RLC
Old 12-01-2011, 10:02 AM   #7
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I'm having similar problems with my engine battery. Have to keep in on a trickle charger all the time when Motorhome is sitting.
Was told by mechanic friend of mine, disconnect either cable, set up a test-light (attached to battery, other end to cable) If light is 'lit', go pull fuses one at a time until light goes out. At that point, you've at least isolated the problem.
Still there may be something more than what I've just described. Cables for battery drawer going in and out could be a problem as well.
Thanks, Derek
Old 12-01-2011, 01:37 PM   #8
Didnt you have a non starting issue before?
Did you press the boost battery button?
Old 12-01-2011, 08:00 PM   #9
crazeevw's Avatar
"Boost Battery Button"? I can't seem to find this magical switch. Location? I've looked in glovebox, but never found it.
Thanks, Derek
Old 12-01-2011, 09:28 PM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Geez, I was not aware that the electrics on the Airstream motorhomes were made by Lucas (the Prince of Darkness, if you must know). Just more proof that there's a strong affinity between Airstream and MG. Or maybe just between Airstream owners and MG owners.
Come to think of it, maybe it is Lucas wiring. In that case, be sure to check to make sure that the wires are properly filled with smoke.
Lynn
Originally Posted by crazeevw View Post
I'm having similar problems with my engine battery. Have to keep in on a trickle charger all the time when Motorhome is sitting. ...Thanks, Derek
WBCCI 21043
Old 12-01-2011, 10:44 PM   #11
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Help... batteries or what?
Greetings Lynn!
Lynn
GM has also had a relationship with Lucas. My dealer told me that it was Lucas that designed the electronic controls for the transfer case in my 1999 GMC K2500 Suburban . . . . that electronic control has a 12,000 to 15,000 life expectancy and the part costs around $750. I have owned the truck since it was new (in fact, I special ordered the truck), so I have been through the routine something like 14 times now. The last time it failed, the transfer case was also deemed unrepairable so my plan is to have the truck converted to 2-wheel drive -- should have had the conversion done years ago rather than at 200,000 miles.
Kevin
Kevin D. Allen
AIR #827
Old 12-02-2011, 06:07 AM   #12
Question Ign....
Lynn
Primary exposure to LUCAS IGN>
58 MGA
65 ROYAL ENFIELD 750
Neither of which had the Ign part quite figured out.
Sometimes made for memorable adventures.
PFC
RLC
Old 12-02-2011, 08:14 AM   #13
Mike Leary's Avatar
Images: 11
Lynn
::::Spews coffee over the keypad::::
Old 12-02-2011, 10:27 AM   #14
Silverton , Colorado
Voltage regulator.
Battery cables from terminal to solenoid will sometimes wear holes from drawer sliding in/out.
Cut-off switch on wall just inside door...this one is a hard-to-find puppy if it needs replacement.
Ignition(key) switch.
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
batteries, charger
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Yikes! My Fantastic Fans Killed My Batteries Alumaholic Batteries, Univolts, Converters & Inverters 20 10-08-2011 08:33 AM
Bad Batteries? Nightwatch Electrical - Systems, Generators, Batteries & Solar 8 05-23-2011 01:58 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
Batteries lost water/electrolyte blickcd Batteries, Univolts, Converters & Inverters 13 03-28-2011 08:26 AM
