Old 07-13-2011, 05:29 PM   #71
Sacramento , California
Well the park closes October 15th so there IS a deadline. As I said, I'm wary of towing the MH and this place is on a different clock than the rest of the world. (For those who don't know there is a mixture of Hispanic, Native, Hippie and Anglo culture here and the first three are on their own calendars).
The daisies have grown a few inches, a finch is building a nest in the "rec room", a rabbit makes nightly visits to feed and then there is the midnight bear. Don't understand how the tenters sleep.
Also, folks, with a 345, it's not like one plans on doing a lot of traveling. Maybe three spots a year. The owner of the park told me his son worked on his Chevy 454 engine with every improvement known to humankind, and he got from 8 mpg to 9.
Will keep everyone posted with updates... or more likely the growth rate of the daisies.
silverdream2 is offline   Reply With Quote
Old 07-13-2011, 05:58 PM   #72
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
Did you ever get the dipstick to go in ? If so what was the oil level ?
steveturk is offline   Reply With Quote
Old 07-13-2011, 06:16 PM   #73
That is the one thing the mechanic did do. He threaded it in like a pro. The oil level is way above ADD. So yes, that is still a problem.
Old 07-13-2011, 06:51 PM   #74
Octane's Avatar
1977 Argosy 28
1977 28' Argosy 28
Lyngby , Denmark
Try giving these guys a call:
Rene's Auto Repair
575-737-0108
575-613-5879
They're right outside Taos on the same road
as the municipal airfield.
I can't recommend them as I don't know them,
but my Argosy was in there for a radiator fix
( at the sellers expense )
when I was in Santa Fe / Taos to check my
newly purchased MH.
They were working on a couple of old MH's
when I was there, besides mine; an old Winnebago
and something else, plus there were a bunch of
old V8's at the premises so an old(ish) Airstream
shouldn't frighten them.
I was just reminded this when I read your thread
and checked a photo I took while there
If you dont follow your dreams, you might as well be a vegetable
Burt Munro
Octane is offline   Reply With Quote
Old 07-13-2011, 06:51 PM   #75
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
SD2,
Make sure that "mechanic" noze not to run'r
Good Luck, hope you can stop watching the daisies soon!!
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-14-2011, 02:10 AM   #76
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Am I the only one bothered by this? If so, I guess I need a different forum.
Waipio Rim is offline   Reply With Quote
Old 07-14-2011, 03:55 AM   #77
Gainesville , Florida
No, you are not the only one bothered by this, but the moderators will let it fly by. jim
Old 07-14-2011, 04:21 AM   #78
On second thought ,I don't think the poster meant any harm. and I think I was being a bit thin skinned. Could be interpretted differently. jim
Old 07-14-2011, 04:29 AM   #79
Me too, Jim.
I fit three of the demographics listed and took no offense.
I just see a not very responsible "mechanic".
PFC
"Tahawus"
RLC
John Prine
Old 07-14-2011, 04:45 AM   #80
Too bad the mh is not where you could just drain part of the oil out in order to do the rest of the work. Could you get a wrecker to pull you somewhere to safely drop the oil? Parking lot ? With the oil in it you can't start it, so I would start there. One step at a time. jim
Old 07-14-2011, 04:46 AM   #81
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
It is a sad day when everything we say is immediately judged to have an offensive overtone. I did not take offense and I and my family could be said to fit all of the above descriptions.
John
shepherd57 is offline   Reply With Quote
Old 07-14-2011, 05:06 AM   #82
Naper's Avatar
Loretto , Ontario
Chances are your problem is the starter. You can very easily take it out yourself. It's only a couple of bolts and a couple of wires. Only one way to put it back in. A starter is one of the easiest DIY auto repairs. Once you have the starter out you will be able to inspect the ring gear. Most parts stores can check your starter.
As for the oil over fill assuming it's only a couple of quarts over it will be OK for a short distance.
Naper is offline   Reply With Quote
Old 07-14-2011, 06:26 AM   #83
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Sounds like this might be a good application for one of those oil extractors that uses the dipstick tube. I've never used one but I know they exist... don't know how well they work, though.
David
Old 07-14-2011, 06:44 AM   #84
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Waipio Rim....Goodbye!
batteries, new engine, oil dipstick
