Old 02-10-2019, 08:35 PM   #1
Lochbuie , Colorado
Heater core needed help!!!
In need of a complete dash heater core assy, for some reason the last owners of my customers 83 mh forgot to mention they removed the dash heater core
RVREPAIRMEN is offline   Reply With Quote
Old 02-10-2019, 08:51 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Okay, ACME supplied Airstream with heater cores for the motorhomes. They weren't a part of the P30 chassis. Try the links below to see if you can come by a close fit.
https://www.millsupply.com/stepvan-p...-and-ac-parts/
http://acmeairparts.com/rvacheaterpa...=0&sort=normal
Look over this thread....yes it's for Argosy, but the front end didn't change and it may give you an idea for what was there.
http://www.airforums.com/forums/f310...-a-180525.html
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 02-10-2019, 09:12 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
If it has already gone, you could also consider installing an aftermarket A/C system from somewhere like Classic Auto Air (I use the Street Rod III kit) that includes a heater/blower.
martin300662 is offline   Reply With Quote
Old 02-11-2019, 05:37 AM   #4
Magnet18's Avatar
Churubusco , Indiana
Cheers
Sidekick Tony
I was going to be asking that question soon as well, so thanks Tony!
Magnet18 is offline   Reply With Quote
Heater core needed for '79 Excella Motorhome. NigelNigel General Repair Forum 0 04-23-2013 10:13 AM
HELP! Heater core leaking realpank Argosy Motorhomes 5 09-21-2010 07:28 PM
Help! Heater core Argosy, '78 28ft ardeleon Mechanics Corner - Engines, Transmission & More... 1 06-28-2009 10:47 PM
How is your Heater Core on MH? RonJudi General Motorhome Topics 7 01-26-2004 08:17 PM
Heater core, Door handle, Lower Radiator hose. josephhh Airstream Motorhome Forums 9 11-19-2003 09:20 PM
