Old 03-30-2010, 03:00 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Heater core 'dead' said radiator shop...
The shop owner took one look at where the leak occurred and he said it was dead. It would cost $135.00 to "re-core". I thought these shops could repair just about any type of radiator core. I will call my RV place to see if they know how to fix it, but sometime before, they told me that they only do coach work and nothing mechanical. Hopefully this is "coach" work.
Where can I get a replacement heater core for my '79/'81 MH?
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 03-30-2010, 04:05 PM   #2
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Thumbs down Heater core "dead"
My friend you are headed for the radiator shop as this is definately not coach work. Radiador shop will recore it for you. That's what you need.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 03-30-2010, 07:24 PM   #3
Astrodokk's Avatar
I went to a different radiator shop that also does AC work on MH's and he said it will cost $176.00 complete to build a new brass core and place it into the heater core frame. I think it's a little high but I can't drive around everywhere getting estimates, so I went ahead and ok'd it. He also said that the AC system rebuild (R134) would be about $1000.00. I need it for the summer so I'll have to bite the bullet for that too. I've heard that it's an average rate for that type of work, so I'm ok with it. It'll be nice to get the MH in shape again and enjoy it the way it should be.
Old 04-04-2010, 10:11 AM   #4
I have had good experiences in my older A/C systems that had R12 with a product called ES12. Its better than R12 yet safe for the environment(thats what the ES stands for).
You loose a lot of cooling power swapping to R134a, because to make it really work, you need to resize the evap and condensor too.
Look here:
EnviroSafe Refrigerants are 30% more efficient than conventional
Old 04-04-2010, 11:14 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Look here:
A heater core is a small radiator that uses heat from the engine by plumbing into the coolant system. It is used to heat air, not cool. Hence the name heater core.
The virtues of one R12 replacement vs another have nothing to do with this topic.
Vaughan
Old 04-04-2010, 11:53 AM   #6
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'm guessing you didn't thoroughly read all the posts before you responded.
Regards,
Ken
Old 04-04-2010, 12:06 PM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
Regards,
Ken
Oops! My bad. Thanks Ken.
Sorry KeyAir, after looking at that again, that really sounded harsh. Didn't mean it that way.
Back to clearing stuff out of the Trade Wind. What I should have been doing anyway.
Vaughan
Old 04-04-2010, 12:13 PM   #8
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Regards,
Ken
Appears you didn`t read post 3 ,where he also said he need AC also. Dave
easyride is offline   Reply With Quote
Old 04-04-2010, 12:17 PM   #9
1983 34' Excella
1967 24' Tradewind
Images: 32
Yes. Again, sorry all.
Vaughan
Old 04-04-2010, 01:51 PM   #10
LOL, even I make mistakes!
No offence taken!
Help! Heater core Argosy, '78 28ft ardeleon Mechanics Corner - Engines, Transmission & More... 1 06-28-2009 10:47 PM
Heater core leak Astrodokk Classic Motorhomes 6 08-17-2008 10:17 AM
345 heater core from engine h20 leak ElliottBartlett Classic Motorhomes 6 03-07-2005 09:20 PM
How is your Heater Core on MH? RonJudi General Motorhome Topics 7 01-26-2004 08:17 PM
Heater core, Door handle, Lower Radiator hose. josephhh Airstream Motorhome Forums 9 11-19-2003 09:20 PM
