Old 04-30-2016, 06:57 AM   #1
nezpique's Avatar
1988 29' Airstream 290
St. Francisville , Louisiana
Headlight replacement
I'd like to change the original headlights on my 290 to something more modern and brighter. Can I find something that will be just plug & play?
Thanks guys!
nezpique is offline   Reply With Quote
Old 04-30-2016, 07:46 PM   #2
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
The answer is yes. If you have the part number of your traditional halogens you can do a search for a comparable CEE LED, but expect the cost for replacement to be around $250.00 for both low and high beams.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-01-2016, 07:49 AM   #3
nezpique's Avatar
WOW, I was told they would be high, but $250 per side?!! I bought some NAPA halogen replacement lights for $10 each. THanks for the input.
Old 05-01-2016, 10:14 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I just replaced the Burb's Low beams with THESE..
Hard to believe the improvement, if the low beams continue to perform well I plan to change the HB's also.
I also recently replaced the fog lamp housings and replaced the halogen bulbs with a HID conversion, even brighter, but the HID headlamps tend to irritate other drivers when used in a non-projection housing. They do work very well for the low mounted fog lamps though.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
LY headlight replacement pol General Motorhome Topics 0 07-21-2015 07:48 PM
Headlight bracket cwlandyacht Land Yacht/Legacy Motorhomes 0 10-09-2011 07:02 PM
Dark Green wire headlight harnes? AirRowan Classic Motorhomes 8 08-08-2011 12:00 PM
Headlight Greetings Marks Our Community 14 09-19-2003 05:21 PM
