Old 04-19-2019, 04:42 PM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Headlight Minder Fuse
I have been replacing the tail, turn, and clearance lamps with LEDs. I have noticed the head/parking lamp switch in the dash gets quite warm after a while and the new lamps clean up things, too.
I usually try to be parked and a couple of cocktails in by dark, but occasionally we need the lights.
Upon replacing the side marker lamps near the wheel wells, I had a socket being a stubborn and in a moment of weakness I poked around at the contacts with a probe and sure enough, I shorted it.
This resulted in silencing the "beeper" that sounds when the lights are on and the loss of power to the side marker on the opposite side of the coach. All the other lamps on the parking light are still functioning.
Does anyone have any knowledge of the location of the "beeper" ?
It seems the logical place to start.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-24-2019, 10:24 AM   #2
jdalrymple's Avatar
Jay , Oklahoma
I found the it. And, I was mistaken: I had also lost the clearance lights on both ends.
It seems Airstream simply spliced into the P30 tail lamp circuit at the headlight switch with a in-line glass fuse holder and routed power first to the ICC Blink switch on the dash.
From there, they powered the clearance lamps and side markers.
The fuse holder can be found by placing yourself upside down in the drivers floorboard.
Perhaps this will help some poor soul in the future.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 04-24-2019, 03:54 PM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Ahh.....the old “Hack” job.....let’s put the fuse here where nobody can get to it trick......another case of making money by mistake, Regards, Bob
bobmiller1 is offline   Reply With Quote
Tire Minder or TST TPMS for 30' FC Beach Bum Tires 8 02-05-2015 12:25 AM
hook up tire minder transmitting booster roloha Electrical - Systems, Generators, Batteries & Solar 1 03-06-2014 08:43 PM
Air Filter Minder maxed out all the time Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 0 04-17-2013 08:51 PM
Battery Minder Question Jwestman Electrical - Systems, Generators, Batteries & Solar 3 11-18-2012 03:22 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
