Old 11-08-2014, 06:23 PM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Has anyone ever removed ALL of interior and inner skin to spray foam inuslation?
This seems to be a HUGE task, one I'm 'toying' with, especially since retirement plans now include Alaska.
If you've done this work, did it make enough difference in interior temps?
Realize it's a TON of work, but in the end, was it worth it?
Thanks, Derek
Old 11-08-2014, 06:37 PM   #2
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
You don't want to go there, trust me. (I'm not talking about AK, or maybe
I am).
Lot cheaper to buy flannel P-J's and run an electric heater or stay S. of the
49th parallel.
Del
Del Gurney is offline   Reply With Quote
Old 11-08-2014, 06:52 PM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
There's a couple threads about this very subject. They are, uh, quite lively discussions.
www.nesa.org
Air No. 6427
Old 11-08-2014, 07:40 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'm thinking you're crazee to do it, and the benefits will not out way the effort or costs incurred do it. It still won't rectify the lack of insulation in the floor and air infiltration from weeping holes and gaps in the windows, which by the way are single glaze.
Also be aware, some foam insulation actually absorbs moisture and trying to regulate the spray thickness not to exceed the thickness of the wall, and yet fill the wall cavity would also be nigh impossible.
Throw out the old furnace, buy a couple of Platinum Cats which use almost no electricity and propane and a couple of Dyson air movers/heaters to augment the Cats.
If it gets really stinking cold.....rent a room cause your grey and black water tanks will probably be frozen.
Just MHO
Cheers
Tony
Old 11-08-2014, 07:42 PM   #5
crazeevw's Avatar
Del Gurney, too late on Alaska. Purchased land a few months ago. Area is remote, and don't know if I'll have electricity for electric heater. Truthfully, I'm looking forward to remote. Been in FL for almost 30 years. Too many folks here for my taste. Ready for me and nature!
Jim, should've clarified. Wondering about Airstream Classic Motorhome having interior removed, inner skin removed, spray foamed, and then re-installing it all. Yes, trailers are similar, but thinking there may be a few differences.
Thanks Derek
Old 11-08-2014, 07:42 PM   #6
Got gandkids?
Where's that unsubscribe button for threads........there it is.
Just kidding! Can't be a lot different. Go look at those other threads. I can't remember if anybody here on the forums actually carried thru with spray foams.
www.nesa.org
Air No. 6427
Old 11-08-2014, 07:53 PM   #7
Dazed and Confused
Isuzusweet's Avatar
Derek
Now you have my curiosity up.
Are you planning on moving to Alaska to build a house and live in the coach while you build?
Are there services near to where your land is?
Cheers
Tony
Old 11-08-2014, 08:01 PM   #8
Dazed and Confused
Isuzusweet's Avatar
Buy a few of these....
45 FT High Cube Shipping Container | eBay
Load them up with materials and furnishings for your house. Use containers to build house or your garage (bear and wolverine proof). Five or six will give you an impressive house.....better still if you bury them into the permafrost and use geo thermal heat pumps.
https://www.google.ca/search?q=shipp...w=1199&bih=917
PS you could make some money filling the containers with items needed in Alaska which would probably pay for the container and the shipping it to Alaska.
Cheers
Tony
Old 11-08-2014, 09:06 PM   #9
1982 28' Airstream 280
Redwood City , California
This is the shipping container home I want to build. I've been wanting to do this for a few years now.
I'll go to Alaska with you Derek...summer time only!Click image for larger version
Name:	ImageUploadedByAirstream Forums1415505957.550717.jpg
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 11-08-2014, 11:34 PM   #10
1988 Argosy 32
Lomita , California
My 1988 argosey squarstream has factory eurothane sprayed in and it seems to work well.(do not try to do it yourself with spray cans, it will not work well FUBAB.)
Wolfe is offline   Reply With Quote
Old 11-09-2014, 05:37 AM   #11
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
In my opinion, the problem with keeping an Airstream warm is not the type of insulation in the walls, but those issues already mentioned...
4" holes in the floor for 1/2" pipes, vented windows, as well as the direct conduction of the exterior sheets through the framing to the interior sheets.
My bet is that one would gain more from removing the interior sheets and applying some kind of thermal break to the frame than simply changing the type of insulation.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-09-2014, 05:40 AM   #12
Dazed and Confused
Isuzusweet's Avatar
What's with us Airstreamers and metal walls????
Old 11-09-2014, 08:52 AM   #13
Del Gurney's Avatar
1965 26' Overlander
Exactly Isuzusweet:
On my '65 i sent the inner walls to recycler and am going to use 1/8 form plywood
instead. Use the pink foam insulation and that'll do me just fine here a few miles from
the Canadian border. In Alaska, in winter at -50 it just is not possible unless your AS is IN a wind proof barn with a wood stove. Then there is septic to consider.
Old 11-09-2014, 09:26 AM   #14
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
With 2 inch thick walls, single pane windows, direct thermal contact to the outside world via the exterior and interior aluminum skins joined by aluminum rivets and tied together with aluminum ribs, numerous penetrations for plumbing and the like, Airstreams are basically three season campers. I can't imagine trying to spend a sub-freezing winter living in one on a full time basis. That would sure take all the fun out of it for me!
Bob Martel
WBCCI# 5766
Has anyone removed the DVD player and box in a 2012 27FB? motozen Electronics & Connectivity 0 06-26-2013 02:44 PM
Removed inner skin Henryck General Repair Forum 4 05-17-2012 04:05 PM
Update, leaks and spray in foam ugggh!! Bex All Argosy Trailers 13 07-25-2010 07:45 PM
Anyone ever removed the Frigerator? 911rs Argosy Motorhomes 10 09-12-2008 06:47 AM
Has anyone ever removed their air conditioning from engine compartment Mr. D Mechanics Corner - Engines, Transmission & More... 19 06-07-2007 07:11 PM
