Old 11-09-2014, 01:22 PM   #15
1964 22' Safari
Naples , New York
Smile alternate approach
Noticing the lack of insulating properties in my 1964 Globetrotter, I purchased 24 cans of spray insulation. I drilled holes through the inner skin inside the cabinets and removed light fixtures and recepticle plates to get additional access to the space between the inner and outer walls. I sprayed the insulation until the can was empty and then sealed the hole with a plastic plug. The plugs pop in place. They are available from hardware stores in the automotive specialty hardware trays. After spraying, you can determine from the temperature drop of the skin how far the foam has gone. Mark it with a pencil and you know where the next can should go.
The insulation has made quite a difference in the roof especially on sunny days. I used the "large gap" variety of the foam.
To do the whole Airstream Globetrotter would probably take 50 cans or a professional application kit. Good luck.
Larry
lletteney is offline   Reply With Quote
Old 11-09-2014, 05:37 PM   #16
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Have you ever removed you interior skin? When you get it off you will find the cavity is so full of wire that there is little room for insulation.
Gregsch is offline   Reply With Quote
Old 11-09-2014, 06:47 PM   #17
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Unhappy
I really don't like the cold,but I do know it would be impossible to live a normal life in a montana winter in an airstream the water and the sewer would be froze solid,
Has anyone removed the DVD player and box in a 2012 27FB? motozen Electronics & Connectivity 0 06-26-2013 02:44 PM
Removed inner skin Henryck General Repair Forum 4 05-17-2012 04:05 PM
Update, leaks and spray in foam ugggh!! Bex All Argosy Trailers 13 07-25-2010 07:45 PM
Anyone ever removed the Frigerator? 911rs Argosy Motorhomes 10 09-12-2008 06:47 AM
Has anyone ever removed their air conditioning from engine compartment Mr. D Mechanics Corner - Engines, Transmission & More... 19 06-07-2007 07:11 PM
