Grosspolutors windsheilds install
Hey,
Well, me and GP had a date to do his glass on his 345. Took us about a hour to get both sides in. Hand lotion helped a lot in getting the rubber over the edge. I am impressed with the rubber quality. Like my windsheild rubber, his was in excellent shape. No splits on the corners, very supple too. His glass had the exact same senerios on the pass side as mine. The glass barely is in the gasket. He'll have to move the gasket down a little the get a good seal. Drivers side was. Perfect, as was mine. Weird eh? It's a two man job. Those little. Bicycle tire demounting spoon things I recommend are perfect for this job. Never use steel, as in screwdrivers. We had a little trouble toward the middle lower edge. Rich was on the inside, pushing the rubber edge out and I was pulling that same area, and pop, in it went. We put the locking rubber in went very smooth. That tool you can buy is probably a better tool. But a blunt nosed kitchen knife worked just fine. We definitely recommend getting the newer style locking rubber. It pushes the gasket down tighter on the glass. And I think it's more supple than the original type. And we left it long in the. Edges, so it can shrink a little. The locking rubber is like a rubber band. With hand lotion in the channel, it will retract to where the rubber becomes neutral. Then Rich will cut off the sticking out part and massage it into the channel. Does your glass have a big gap where the locking rubber has shrunk? That's why we both decided to go with new rubber. Hope all this info helps. Rich took a video of this. Don't know if it's good enough to post. He'll asserting that later. To all, this job is totally doable. On a scale on 1-10 I give it a 3-4 pretty easy job. Thanks rich, we had a good time. DJ
