Old 12-02-2011, 09:36 PM   #29
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Yup.
I started with the water hose reel, and now am in the underbed area...
Using 1/2" piping, and to be cool, Red for Hot water and Blue for cold.
I looked at a few different systems, and ended up using PEX.. the crimp tool was $50, but you save money after that because the fittings are cheaper.
Steve,
Where did you find your PEX tubing?
Thanks, Derek
Old 12-02-2011, 10:33 PM   #30
The red I got at ACE Hardware, and the Blue at Home Depot..
Old 12-02-2011, 11:51 PM   #31
1974 Argosy 20
Kooskia , Idaho
I see that Home Depot has now begun to use the term "Sharkbite" with both the push on fittings as well as the crimp ones. The PEX pipe they carry now is also called "Sharkbite" so we will need to start to call the push on type fittings something like "push on" as both kinds are now labeled "Sharkbite". You can see that in the photo posted a few posts back.
Just when you thought you had it all straight, eh? And I think Lowe's push on's are called something like "Tigerbite" to add to the confusion.
Sealing up plumbing openings KYAirstream Plumbing - Systems & Fixtures 3 09-05-2011 09:41 PM
copper plumbing in 1965 Trade wind Dr Dan Fresh Water Systems 5 07-14-2011 07:41 PM
Sikaflex 221 gray? AirHog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-19-2011 12:22 PM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
