Old 03-07-2018, 08:36 PM   #1
1982 31' Airstream 310
Tulsa , Oklahoma
Got the 310 - but not the jacket
You've all heard or read the story of the 310 jacket. About a year ago, I purchased the 1982 - 310 from Peter H Airstreamer, but I couldn't talk him out of the 310 jacket! Oh well, maybe someday.
The 310 was in storage for a few months until I could get a shed built for it. Only a few short trips locally. So the last few months I have been busy getting to know it and doing some things "on the list"
I just wanted to introduce myself and I hope to get to know more about the great classics.
Hope to soon be ontheroadagn
ontheroadagn is offline   Reply With Quote
Old 03-08-2018, 05:33 AM   #2
Welcome to Airforums and congratulations on your 310 purchase!
Is this the 310 that has the aftermarket fuel injection system?
We all know the only reason Peter buys Airstream motorhomes is to collect the jackets. Sure does seem like an awful expensive way to get a jacket!
Old 03-08-2018, 08:21 AM   #3
Tulsa , Oklahoma
Yes it has an early model Holly throttle body fuel injection. 950 Commander I believe it's called. Runs good.
Old 04-19-2018, 08:59 PM   #4
Tulsa , Oklahoma
I need some help finding a coolant temp sending unit for a second Teleflex temp gauge. The one in the dash panel works fine. I have a second one in a 3 panel below the dash along with a transmission temp and coach battery voltmeter. The second one has never been hooked up. It was wired in for power and lights but never had a sender or sender wire to it. I have located a Teleflex sender (p/n TS26631) that was suppose to be the right one. Installed in the other head - same location. When installed and hooked up, the gauge reads pegged HOT. It ohm tests at 630 ohms at 73 degrees F. I found a chart online for Teleflex and it says they should be 600 to 800 ohms at room temp.
If I swap the wires with the dash panel sender, the dash panel gauge reads pegged HOT and the second gauge reads correct. So I removed the Dash panel sender and ohm checked it. 3000 ohms at 73F ! Huge difference. There are no markings on it as far as make or part number.
I have tried a sender from stewart warner that ohm checked at 854 but got basically the same thing, pegged HOT when the dash gauge was at 185 F.
Anybody have any ideas or a source for Teleflex info?
Dave
Old 04-19-2018, 10:20 PM   #5
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Dave
Dave, I got those Teleflex gauges at a rare Ebay auction and snapped them up. Unfortunately they came without any documentation. Sorry, but can't help on this one.
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 04-20-2018, 08:51 AM   #6
Tulsa , Oklahoma
Thanks Peter - so all gauges - no sending units with them?
Now that I know how to, I will post some pictures soon to show you what I been up to over winter.
I just cleaned and backflushed the cooling system with BG Cleaner and replaced all the coolant hoses, including the heater hoses to the back heater (47 feet of gates green stripe 5/8 heater hose) which is why I wanted to hook up the second temp gauge while I had everything drained.
And rebuilt the aux heater
Davew
Old 04-20-2018, 09:00 AM   #7
Tulsa , Oklahoma
And replaced all of the furnace duct.
and reworked some of the duct work
More later
Dave
Old 04-20-2018, 05:26 PM   #8
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Attachment 309094
Attachment 309096
Attachment 309097
Attachment 309098
Davew
Nice clean work, the way it should be done, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-25-2018, 09:19 PM   #9
Tulsa , Oklahoma
I gave up on finding a sending unit for that Teleflex gauge. Just installed a new Temperature gauge/sending unit combo.
Finished installing the storage drawers and battery drawer after putting new stainless steel bottoms in themClick image for larger version
A lot of corrosion. Cut out bottoms and welded in some 404 stainless
Primed with epoxy primer and painted the battery box with Acid proof battery box paint
Old 04-25-2018, 09:35 PM   #10
Tulsa , Oklahoma
Also replaced the relay solenoid on the back of the battery drawer. The old one was toast.
The drawer slides work sooo nice when all cleaned up and lubed.
The story of the Airstream 310 Jacket PeterH-Airstreamer Classic Motorhomes 645 01-10-2019 06:33 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
