Old 04-09-2016, 10:23 AM   #85
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
I think I will make a cover for mine. On out last trip it had snow on the inside, and I want to put my new used Magnum inverter up there as well.
SebasSF is offline   Reply With Quote
Old 04-10-2016, 10:44 AM   #86
SebasSF's Avatar
New air filter installed. I will take photos of the finished project next time.
I was able to trim a bit off the sides of the filter so I did not need to make a wider hole and modify the cover.
Name:	ImageUploadedByAirstream Forums1460302845.925670.jpg
ID:	260326Click image for larger version
Name:	ImageUploadedByAirstream Forums1460302872.242062.jpg
Old 04-10-2016, 09:08 PM   #87
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
SebasSF, those are some nice mods you have going on. I too am looking at an inverter in the future. Current plan is to put it up front and add the length to the AC side of the wiring, rather than the DC to prevent voltage drop over distance. Have not figured out how to tackle it yet. I was looking at a full Xantrex system, but so many people offered negative impressions of it I have since looked at a magnum 2800watt inverter charger.
One of my other plans is to install zeus fasteners (quarter turn fasteners used in aviation) for the air filter grill for ease of maintenance. Have you thought of doing that?
Also need to add 600w of solar to the roof.
I need to get on it because I am planning on doing a Newfoundland trip in JUL/AUG of this year.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 04-14-2016, 01:05 AM   #88
SebasSF's Avatar
Thanks Vycan. Having the inverter next to the batteries is obvious when you look at the wire size needed to run an inverter off batteries compared to the #10 AC wire needed. I am going to install one solar module on my roof. I am in the solar industry, and I just want it to keep batteries charged when it's parked. When I'm using it, I typically drive for a stretch charging up the batteries, then camp overnight or for a day. If batteries start to get low and I'm not at a campground I can run the generator, so think through your use case before spending a bunch of money on solar. I don't really even have much of an application for the inverter, I must like the quality charger and monitoring panel. I think I will take out the convection microwave unit and install a range hood and a proper oven like the Dickinson Marine unit...
Old 04-17-2016, 12:46 AM   #89
SebasSF's Avatar
Finished the air filter housing project, and close to done on the bed...
Ran out of plywood, so there are two blocks holding it together. I decided to block up the cabinets remove the tops, and run the back shelf all the way around...looks good.
Name:	ImageUploadedByAirstream Forums1460871778.205987.jpg
Name:	ImageUploadedByAirstream Forums1460871829.968321.jpg
Name:	ImageUploadedByAirstream Forums1460871870.961559.jpg
Name:	ImageUploadedByAirstream Forums1460871799.105385.jpg
Old 04-17-2016, 04:05 AM   #90
1995 36' Classic 36
Ludington , Michigan
Looks good. I shortened up my cabinets on the sides too. It was just dead space.
Kota is online now   Reply With Quote
Old 05-25-2016, 11:19 PM   #91
SebasSF's Avatar
Moving bed back project is close to finished...
Name:	ImageUploadedByAirstream Forums1464236326.038083.jpg
ID:	263260Click image for larger version
Name:	ImageUploadedByAirstream Forums1464236342.813307.jpg
Old 05-25-2016, 11:25 PM   #92
SebasSF's Avatar
Did some major Glamping last weekend out in Stinson Beach! We had out 10 year anniversary party and took the Airstream along...just managed to back it in. It was a great chill and center point for our party.
Name:	ImageUploadedByAirstream Forums1464236586.610381.jpg
Name:	ImageUploadedByAirstream Forums1464236616.649806.jpg
Name:	ImageUploadedByAirstream Forums1464236691.285174.jpg
ID:	263266Click image for larger version
Name:	ImageUploadedByAirstream Forums1464236708.441944.jpg
Old 05-29-2016, 10:12 PM   #93
Vycan's Avatar
Manhattan , Kansas
Love the look of your flooring! I too plan to adjust the bed like Dave did, but have not gotten to that item on my list yet.
Old 06-09-2016, 09:33 PM   #94
SebasSF's Avatar
Replaced the original muffler with one from Banks and some custom pipe. We'll see how the modifications do next week driving up to Oregon. One small mod helped a lot- I shortened the rod on the turbo bypass actuator...more boost and less smoke. I can hear the turbo spooling sooner and staying on longer.
Name:	ImageUploadedByAirstream Forums1465526003.066930.jpg
Name:	ImageUploadedByAirstream Forums1465525895.312540.jpg
ID:	264112   Click image for larger version
Name:	ImageUploadedByAirstream Forums1465525947.145897.jpg
Old 06-10-2016, 05:02 AM   #95
1995 36' Classic 36
That's the exhaust brake. The turbo bypass looks like this.
Name:	ImageUploadedByAirstream Forums1465552957.658428.jpg
Old 06-10-2016, 10:44 AM   #96
SebasSF's Avatar
Thanks Kota, the photo was showing the exhaust 🙂
Old 06-10-2016, 05:49 PM   #97
1995 36' Classic 36
Been considering replacing mine. Think it made a significant difference?
Old 07-05-2016, 11:17 AM   #98
SebasSF's Avatar
Hey Kota, after my last road trip up to Oregon, I'm not sure it made a big difference, but it sounds good! I'm looking for the best balance of power, mpg, and low egt...
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 05:47 PM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 07-24-2010 11:20 AM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 07-14-2010 12:20 PM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 06-29-2010 11:20 PM
Need an inspection in Houston. 95 Diesel Pusher Classic Griffin WBCCI Forum 1 03-19-2007 08:56 PM
