Old 07-29-2015, 09:49 AM   #29
1994 36' Classic 36 Diesel
Morton , Illinois
I love the flooring! Our PO put marble and glass tile on the bathroom floor, walls and galley walls. It's beautiful, but I wonder about the extra weight (had to be significant). The grout will eventually be destroyed by travel, and we will replace floors with wood.
CLKIESER is offline   Reply With Quote
Old 07-30-2015, 02:18 PM   #30
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Made it to Jasper Alberta with zero issues. Jacksonville OR and some khakis in the Rogue, Portland with friends, Vancouver and picked up Mom, over some crazy mountain pass going the back way from Whistler to central BC and Kamloops with relatives. Stunning drive up to Jasper and relax with the brother!
Name:	ImageUploadedByAirstream Forums1438283899.658979.jpg
SebasSF is offline   Reply With Quote
Old 07-30-2015, 08:46 PM   #31
1995 36' Classic 36
Ludington , Michigan
Looks like my kinda trip!
Kota is offline   Reply With Quote
Old 08-09-2015, 02:12 AM   #32
Vycan's Avatar
Manhattan , Kansas
Nice work SebasSF!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 08-09-2015, 06:54 AM   #33
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Very nice work! Thanks for the info on the thermal/sound proofing for inside the engine doghouse! I will give them a call this week and see about what I need.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 08-09-2015, 07:08 AM   #34
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That is a beautiful diesel pusher. I admire the work you do, and I like the "fix it correctly" attitude.
What a nice ride!
"Long lay the world in sin and error pining
Till He appeared and the soul felt its worth"
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 08-10-2015, 01:05 AM   #35
SebasSF's Avatar
Made it home! 3250 miles with my wife and son. All the way up to Jasper Alberta Canada and back down through Banff, Sand Point Idaho, Bend OR, and home. We took on some crazy mountain passes, saw bears and elk.
We had one mechanical adventure out of Spokane. The AC compressor looks like it came loose and got hit by the fan. I did not notice apart from no AC until I went to check the oil and it poured right out the bottom- through the broken filler tube. The fuel return was almost worn through from having the compressor sitting on it and actually started to spray a nice mist of fuel into the motor. I managed to patch everything up and drive 30 miles to the Cummins distributor and got most of the parts I needed to repair it myself and get back on the road...lucky to have a nice set of pliers to straighten out the fan and some extra fuel line and hose clamps to patch the fuel line.
We also lost a bolt from one side of our front shocks and had the remaining one blow out just before arriving home...good timing.
Did I mention the usual headliner sag finally got us as well...
Fun trip, great RV, drives great and does a good job on fuel consumption.
Old 08-10-2015, 03:20 AM   #36
1995 36' Classic 36
GLAMP '94 Classic Pusher
Sounds like a great trip!
Did you talk to the shop that did the engine rebuild about the compressor falling off?
I've taken the filler tube off both of mine. Found it easier to service the oil through the cap on the #6 valve cover. I've never had to add oil between seasonal oil changes.
I've got to deal with headliners on both mine. Let us know what you decide to do with yours.
Hope you post some pictures of your trip.
How were the boarder crossings? We sold our cabin in Ontario after the Patriate Act BS kicked in. Got to be a real hassle.
Old 08-11-2015, 01:38 AM   #37
SebasSF's Avatar
Some pics:Click image for larger version
Name:	ImageUploadedByAirstream Forums1439274978.093388.jpg
ID:	245237Click image for larger version
Name:	ImageUploadedByAirstream Forums1439275007.555928.jpg
ID:	245238Click image for larger version
Name:	ImageUploadedByAirstream Forums1439275028.799350.jpg
ID:	245239Click image for larger version
Name:	ImageUploadedByAirstream Forums1439275049.924640.jpg
ID:	245240Click image for larger version
Name:	ImageUploadedByAirstream Forums1439275066.846998.jpg
Old 08-11-2015, 02:36 AM   #38
1995 36' Classic 36
That's Airstream camping! We hope to take ours up to Alaska in a year or two for the summer.
They probably didn't have to remove it in the rebuild, but the air compressor mounting and pan bolts seem to be prone to loosening.
Did you stop by the AS shop in Spokane? Mine came from that area and was serviced there. I've been meaning to stop in on an overnight and check them out.
Old 08-11-2015, 10:12 PM   #39
SebasSF's Avatar
Spartan is asking $740 for a fan, and I'm not even sure if you can swap one out without taking the radiator CAC and shroud off!
Any ideas? I will be talking to the shop hat did the rebuild for sure.
Old 08-11-2015, 10:19 PM   #40
SebasSF's Avatar
Hey Kota, the border crossing was zero issue on the 5 up and 97 down even with my questionable credentials. I did not check out Airstream in Spokane. Believe it or not, after two years in business, our local Bay Area Airstream is now the largest in the US.
I'm thinking about aluminum headliner, or birch veneer with slats. I would do aluminum, but the end caps are the high dollar issue.
Old 08-11-2015, 11:40 PM   #41
1995 36' Classic 36
That fan should be pretty common. Freight liner might have the same one. Buying parts from Spartan will put a hurt on your wallet. Often 2 to 4 times the price I find at the local truck shops. Cummins probably has them.
The radiator assembly isn't hard to pull. I've done it twice. I can do it in about an hour. In and out. I can give you more info.
http://www.ebay.com/bhp/dodge-cummins-fan. Just as a reference on price.
Old 08-12-2015, 10:38 AM   #42
1995 36' Classic 36
Now that you have some time in it, how would you compare it to the 300LE?
As I mentioned, pulling the radiator is pretty easy and open up the engine compartment for walk up repairs. My thread on the KDP in mechanics corner has pictures. You might be able to get the fan off without but it will require laying on the engine and a shitload of foul language.
You might be able to slide the shroud straight back after removing the 6 bolts across the top and 4 across the bottom. Remove the belts and it should slide up against the engine giving some room to get the bolts out and remove the fan. It's a heavy beast!
If it will get you by for a bit I might have one available. I'm considering installing a hydraulic puller fan mounted on the back side. I have my eye on the setup from a side radiator Spartan EC2000. Waiting for the guy to decide if he is going to part it out.
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 05:47 PM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 07-24-2010 11:20 AM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 07-14-2010 12:20 PM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 06-29-2010 11:20 PM
Need an inspection in Houston. 95 Diesel Pusher Classic Griffin WBCCI Forum 1 03-19-2007 08:56 PM
