Old 03-14-2014, 10:51 AM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Genset spark plugs
Not sure if this should be here or in the mechanics section but.....ive searched quite a bit and cant seem to find the following;
Correct spark plugs for my 1983 onan, 6.5, genset. Ive searched and keep getting conflicting answers. The plugs that were in it were two different brands, one a thin wire and one standard, i assume thats not correct! Please help!
mayco is offline   Reply With Quote
Old 03-14-2014, 11:10 AM   #2
mayco's Avatar
Ah ha! I think i found it: champion RN5c
So if anybody needs it, i believe thats it
Old 03-16-2014, 08:35 PM   #3
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
I have the smaller 4 KW Emerald Plus BGE and I think it takes 167-0263 (Onan number) plugs. It's a horizontally opposed F-head twin running on LP gas.
Tony T
2000 28' Classic TT
1994 30' Land Yacht M/H
tony6373 is offline   Reply With Quote
Old 03-16-2014, 09:01 PM   #4
1974 Argosy 20
Kooskia , Idaho
I sold my 310, but now that you state the number RN5c it rings a bell in my mind.
Old 03-17-2014, 12:28 PM   #5
mayco's Avatar
Well.......im afraid i gave some wrong info on those plugs. For my genset model 6.5nh-3cr/16004p, which is propane fueled, the correct plugs are champion rs17yx. Sorry about the wrong info there. Not sure if those others were for the gas motor or not but they were not correct. The rs17yx should be gapped at .025. Installed with new plug wires and air filter and the genset is running great. Sorry again about the wrong info!
No spark from stove burner pilot KerriO Stoves, Ovens & Microwaves 8 01-16-2012 10:37 PM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
To Haul The Genset To Michigan, Or Not murreywalker On The Road... 17 07-04-2011 07:40 PM
Genset will not crank tictoryde Generators & Solar Power 5 05-28-2011 11:08 AM
Spark plug wire looms shepherd57 Mechanics Corner - Engines, Transmission & More... 1 03-13-2011 08:00 PM
