Old 04-09-2011, 05:32 PM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Generator Surging
I have a Kohler 7kw propane powered generator in my '84 310 and when we run it, it won't hold a steady rpm. Even under load, it speeds up and then slows down and then speeds up and then slows down and ... Does anybody have an idea (a) what causes this, and (b) how to cure it? I don;t think there is any serious problem, as the output current is pretty steady or at least seems so, but it is annoying at best and possibly harmful.
Thanks for your expertise. Jamie
jking is offline   Reply With Quote
Old 04-09-2011, 05:50 PM   #2
I don't know, but mine did that when the oil was low....
Old 04-09-2011, 06:30 PM   #3
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
check the fuel pressure
John H. is offline   Reply With Quote
Old 04-09-2011, 06:45 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If the gas line was sucking air it would surge. Find the manual it should say what gas pressure is required. Kinked lines could cause. Surging on a gasoline generator happens when the carb needs cleaning of old gas residue, with propane it might be the flow setting. Reduce the load and let it warmup longer, after spraying carb cleaner in the air filter has been my easy fix. Did you check the air filter and it's summer winter position for air intake.
Old 04-09-2011, 07:35 PM   #5
r carl's Avatar
Lin , Ne
Some water in the carburetor will cause that. Does the float bowl have a drain plug?
Old 04-10-2011, 07:25 AM   #6
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
I had a bad spring on the govener arm. It was hunting (surging) badly voltage would go from 80v to 150v 40Hz 80Hz. If yours is surging do not run any compresors (AC, Ice maker, blender etc.) your charger should keep up with it.
AirRowan is offline   Reply With Quote
Old 04-10-2011, 08:01 AM   #7
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
no expert but I was having surge problems with my gas onan. It was the choke.
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 04-10-2011, 08:18 AM   #8
Cypress , Texas
When was the last time the generator had a tune up, new spark plug, fuel filter, etc.?
Ken
2008 Cameo 35SB3, 2012 Ford F350 Crewcab DRW. Travel companions..1 Wife, 1 miniature schnauzer, 1 standard schnauzer and one parrot.
TXiceman is offline   Reply With Quote
Old 04-10-2011, 10:08 AM   #9
He said it is Propane powered....
Old 04-10-2011, 11:29 AM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Since it is propane. I would go with the generator governor and then the pressure.
Michelle TAC MT-0
Sarah, Snowball
Old 04-10-2011, 12:16 PM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Propane carburetors don't have floats or float bowls. The propane carbs are very simple and reliable. My experience has been that the regulator can cause problems like this.
I worked on large stationary engines and saw this occasionally, though rarely. The fuel gas (propane converted to a gaseous state) pressure needs to be held constant, for the carb to work properly. It is possible that the diaphragm in the carb is sticking or has developed a pinhole(s), but I would check the pressure first. If there is a problem, replacing the regulator is a simple fix.
As mentioned earlier, checking the governor linkage and spring are worthwhile.
Vaughan
Old 04-11-2011, 07:00 AM   #12
Jamie
jking's Avatar
1984 31' Limited
Thanks to everyone who responded. The propane pressure is steady and within tolerances, suggesting the regulator is OK, so I checked out the other ideas and found the spring that holds the governor arm back was perished. A simple replacement fixed the problem. This forum is truly amazing!
Thanks again,
Jamie
Old 04-11-2011, 02:59 PM   #13
Awesome news!
Good detective work on your part!
Old 04-11-2011, 08:24 PM   #14
AirRowan's Avatar
Key West , Florida
What kind of propane set up factory or something after market? Hi or low pres? Do you have a vacume shut off and how much propane do you burn an hr 1# or more? I need to switch my system over and I do not know what one to go with.... I am changing my fuel so I no longer will carry gas and do not feel like dropping 10k on a diesel! Here are some of the propane webpages
