Old 05-16-2011, 02:28 PM   #1
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Generator runs... batteries provide power...
But the generator simply is not charging the batteries! Is there something I'm missing?
GREENovaters is offline   Reply With Quote
Old 05-16-2011, 03:40 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
How do you know? Are you putting a meter on the batteries with the gen set running?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-17-2011, 02:30 PM   #3
Registered User
1995 36' Classic 36
Images: 14
No, the Magnum battery charger remote (ME-RC) was showing nothing and the plug tester showed nothing while it was running. Now, when I plugged in to shore power the remote showed the batteries charging.
Also, on the panel above the stove the GEN light comes on and the switch on the dashboard lights up while the generator is running - I can shut the GEN down with either switch BUT I can't get it to start up! I can start the GEN by using the switch directly on it. Ideas?
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
New Batteries - 6V vs. 12V Wolfie Batteries, Univolts, Converters & Inverters 7 05-07-2011 02:13 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
Batteries lost water/electrolyte blickcd Batteries, Univolts, Converters & Inverters 13 03-28-2011 08:26 AM
