Old 03-01-2012, 06:54 PM   #1
1982 28' Airstream 280
Elkmont , Alabama
Generator runs air conditioner, no AC current
1984 Airstream 280
Onan Generator 6.5
Problem is there is no AC coach power when plugged into generator outlet.
Generator runs and runs one air conditioner but doesn't make AC power.
I checked breakers in back closet and checked breakers on Onan.
AC power works when plugged into shore power.
Thanks in advance.
deltatango is offline   Reply With Quote
Old 03-01-2012, 07:32 PM   #2
1974 Argosy 20
Kooskia , Idaho
The coach power works when plugged in to external power but nothing 120 volt related works when plugged into the generator outlet. Is that right?
And the rear AC unit runs when the generator is running, is that correct?
If so, here is my best guess:
The onan on those rigs has two windings, each with about a 30 amp output and each go through a little 30 amp push in breaker on the generator (which you say you checked).
It sounds to me like one of those two breakers is open, the one which supplies the generator outlet. The other one only feeds the rear AC unit, and must be working.
Those little Onan breakers are not really reliable. When I had my 310 I wound up bypassing them and putting a separate house stile 2 position 30 amp breaker box in the generator compartment.
If you have a meter, check the voltage on the input and output side of those two little push in breakers. I bet you will find one is open.
If power is getting through both breakers on the Onan, it has to be a problem in the #10 wire that goes to the generator outlet or the outlet itself.
Mine had an automatic transfer switch, which also could be the problem, but since you said you have a generator outlet, I am assuming you don't have an automatic transfer switch.
Last thought: If you have 120 volt power to everything but the front AC unit when on the generator, remember that there is a microwave/AC switch somewhere in the Kitchen. It must be in the AC position to make the front unit work.
Old 03-02-2012, 09:40 PM   #3
Elkmont , Alabama
Thanks, I'll start with those little breakers.
What is that box in the cabinet below where the plug to the generator is? It is like a breaker box. There is some stuff in it. What does it do? I suspect that thing is the problem.
Old 03-02-2012, 11:45 PM   #4
1974 Argosy 20
Kooskia , Idaho
Hmmmm, that sounds like you have both a generator plug and an automatic transfer switch. If so, the transfer switch is a very good possibility of being the problem. Can you take a photo of it? If it is about 6" square and about 3" deep and has 120 volt wires running in and out of it, it could be a transfer switch. The time delay system in them fail, as well as the relay contacts.
Mine had a cord reel, and I thought only those had a transfer switch, but maybe AS put them on all rigs, so there would be no load on the gen set when it was trying to start.
The one on mine was very hard to get at, and thus repair.
Old 03-05-2012, 10:35 AM   #5
Elkmont , Alabama
Yes it is a transfer switch, manufactured by Todd Industries (30 amp).
Mine is easy to get to.
What does it do? Should I just replace it? $100
Thanks again.
AIR Midwest : AIR Midwest Spring Rally 2012 LawChick Forum Rallies & Meet Ups 259 05-13-2012 12:18 PM
Lots of Generator Questions!! lewishw Boondocking 45 03-02-2012 09:12 PM
Lifan Inverter Generator TankerIP Generators & Solar Power 10 03-02-2012 02:06 PM
air stream excella 500 eBay Watch Airstreams on eBay 0 03-01-2012 12:40 PM
High Flow Water Pump - yes / no ? MrJ Mechanics Corner - Engines, Transmission & More... 7 02-28-2012 11:07 PM
