Old 06-29-2010, 06:42 PM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Question Generator Propane Consumption?
Does anyone have an idea what the "normal" propane consumption should be for the Kohler 7kw generator? Mine ran a full tank dry in two hours, which seems mighty short.
jking is offline   Reply With Quote
Old 06-29-2010, 07:17 PM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Here's some guideline info. from the folks at US Carburetion ...
Fuel Consumption
The short version is that one KW requires about two horsepower (under load)
while those two horsepower require about 20,000 BTU per hour
while propane contains about 92,000 BTU per gallon
and a gallon of propane weighs about 4.2 lbs.
So, a 7 kw generator ought to need about 14 hp. at full load, using about 140,000 btu per hour or a little over 1.5 gallons per hour or a little over 6 pounds per hour, if my math is right.
I've never run my generator long enough on propane to run a tank dry, so no real-world experience to relate, and these guidelines are the best I can do to help.
AirsDream is offline   Reply With Quote
Old 06-30-2010, 07:00 AM   #3
Jamie
jking's Avatar
1984 31' Limited
Thanks for the basic info - pretty much agrees with the standard text - given the average 30% energy efficiency of internal combustion engines and the puny 21 gal tanks in the classic A/S mohos, that means the best we can expect is about 4 hours. I'll also see what the OEM has to say. Thanks again.
Generator vs Propane LittleA Generators & Solar Power 5 05-12-2009 03:11 PM
Can a propane generator freeze the regulator? richschafer LP Gas, Piping, Tanks & Regulators 4 07-10-2007 05:33 PM
Propane generator hmurfee Member Introductions 0 06-26-2007 12:35 PM
Options for Converting Generator to Propane bhayden Generators & Solar Power 3 11-28-2006 12:40 PM
Propane Generator Help Please Snadi LP Gas, Piping, Tanks & Regulators 11 09-25-2005 05:03 PM
