Old 01-21-2015, 07:52 AM   #43
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
happy camper
we have a GV in our 1977, and, notwithstanding the wiggly gauges, in OD @ 62 mph, the 454 turns at about 2300 rpm. like it a lot!
only wish that the Allison converter in the TH400 would lock....
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 10-20-2015, 12:57 AM   #44
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
If anyone is interested, I have a GV for a Chevy/th400 that came out of a low mile1995 (or thereabouts) Land Yacht. It has been professionally rebuilt with a new cone clutch and comes will all parts. Looking for $2000 plus shipping if anyone is interested before I put it on eBay. I also have a spare parking drum brake assembly. Send me a pm.
SebasSF is offline   Reply With Quote
Old 10-20-2015, 07:11 AM   #45
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
That sounds like a good deal, for sure. But, I doubt though that it is 1995. I am willing to be corrected, but I believe that from 1994 the Land Yachts would have had the 4L80E electronic overdrive transmission with an automatic parking brake. I believe that 1993 would be as new as it could be. I had a 1994 with the later configuration, and have seen 1993's with the earlier transmission and parking brake.
A guy has to be cautious about matching these GV units to applications, and you would need to be sure of rear axle ratio (pretty sure this would be 4.56:1 in all cases), model of transmission, and type of parking brake before buying. GV technical assistance are very helpful (but busy) and given the serial number on the unit, they would be able to tell a buyer exactly what that unit is for.
I'd encourage fitting these: they are great units, and a pretty easy install.
1989 345LE
Punch is offline   Reply With Quote
Old 10-20-2015, 07:30 AM   #46
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Might be better to install a higher speed ring gear and pinion, like a 3.78
Old 10-20-2015, 03:41 PM   #47
SebasSF's Avatar
Thanks for the info Punch, I'm sure you are correct. The model is 3DO475 and retails new for $3695. I was going to install it myself, but my local RV shop quoted me $250...much better idea.
Old 10-20-2015, 07:34 PM   #48
Rivet Loser
Punch's Avatar
It is probably the identical unit to mine.
If I could have found an install for $250 I would have gone for it. Actually I would have done so for $750! The front drive shaft has to be shortened 14" or so, and then all three shafts should be balanced. Iin fact GV say balance the brake drum too, but nobody could do that here). With new carrier bearings and UJ's, which a guy might as well replace at 120K miles, the driveshafts alone cost me $1100. Stuff is expensive up here, but they did do a beautiful job on it.... it's a pity it is hidden under the car!
Altogether the install itself was probably 4 hours though, and would be a lot quicker next time. The most fiddly part was extending the parking brake cable. Caused some bad language and a definite Karma deficit.
1989 345LE
Old 10-23-2015, 09:18 AM   #49
1999 35' Cutter Diesel Bus w/slide
Sacramento , California
JD, I just have to ask, did you take the 350 LE to Burning Man this year? I saw one somewhere around 9:00 and H or so. I went by twice to say hi but nobody there. I was at 4th and F in my 1999 Airstream Cutter. And you're right, many of us have more than one Airstream. Next year I am caravanning in my Cutter and my 1995 36 Classic with a few friends.
Ryker is offline   Reply With Quote
Old 10-24-2015, 01:19 AM   #50
SebasSF's Avatar
Posted on eBay if anyone is interested.
Old 06-20-2016, 11:56 AM   #51
KB6YAF's Avatar
Olympia , Washington
Gear Vendors for my '83 310
I bit the bullet and had the Gear Vendors Overdrive unit installed in our '83 Airstream 310TD. I couldn't be happier. My hearing is no longer taking a beating too
Russell Decker
Olympia, WA
1983 Airstream 310 TD "RussBus"
KB6YAF is offline   Reply With Quote
Old 06-23-2016, 12:15 AM   #52
SebasSF's Avatar
Just remember not to use it for gearing down when going down hills, and be very gentle in reverse.
Old 06-23-2016, 01:52 PM   #53
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
Gear Vendor OD
a PO of our 1977 Argosy 20 installed one in our coach, probably some time in the 1990s, and is still going strong.
had a minor problem with it jumping out of OD on our 2012 coast-to coast run; GV tech support correctly diagnosed an electrical issue over the phone. crawled underneath the coach at our next coffee stop, and repaired the issue in about 3 minutes.
in 3rd gear + overdrive, at about 62 mph, the 454 spins at about 2,300 rpm!
like it, at lot!
Joseph & Gabrielle
Old 11-22-2017, 10:01 AM   #54
KB6YAF's Avatar
this is a reply to my response.....my GV OD unit is not working now....a little over 2 yrs and 24k miles. NOT happy.
Old 11-24-2017, 06:23 PM   #55
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A couple a few years ago I was posting that my research on these devices had not turned up good results,,,, and that an overdrive transmission might be a smarter move,,, but I was kinda shot down... just sayin....
Old 11-24-2017, 06:57 PM   #56
The 4L80E series GM Transmissions, are 4 speed, OD transmissions with a lockup convertor. They bolt right onto the 454, or LS and are the successor to the TH400, and TH475 transmissions.
The E dictates, they need a electronic controller... either stand alone, or linked to the TBI, or EFI on the engine.
The 4L80E is rated at 440ftlb of torque and 18,000lb GVRW
The 4L85E is rated at 460ftlb of torque and also 18,000 GVRW.
However, it is my understanding that the 85 has straight cut sun gears... like the TH475.
https://en.wikipedia.org/wiki/GM_4L80-E_transmission
1978 Argosy Steering Gear Leak stereoeric Argosy Motorhomes 3 09-05-2011 11:38 PM
US Gear Overdrive 1982 310 Diesel FIX 44tonner Classic Motorhomes 4 07-07-2011 09:56 AM
Caution, for those running Gear Vendors Units John H. Classic Motorhomes 7 05-07-2011 11:02 PM
Gear Vendors pjude Classic Motorhomes 4 03-20-2011 11:32 PM
