Old 09-01-2016, 07:21 PM   #1
1991 35' Airstream 350
Mentor , Ohio
Gaucho issues
I am in the process of re-installing a gaucho (electric couch/bed). I don't have the original switch. I am guessing the switch is a three position switch (forward - stop - reverse) that is biased to the middle (stop) position. Does anyone know the source of such a switch - is one still available or, alternatively, who sells a modern version of such a switch? Also, I am not sure where the switch was originally mounted - not sure that that matters - but it would be nice to put it back in a 'normal' location.
Also, I have noticed from other's photos that the gaucho originally had stationary arms - i.e., arms that don't move as the gaucho moves from couch to bed configurations. I don't have the arms - or anything that might have been on the ends of gaucho. Could someone let me know how those arms are mounted (I don't see any place for them to mount on the gaucho frame. Maybe I am missing something else that they mount too?). I also need the dimensions of the arms - I will have to make some and have them upholstered. Any photos would be appreciated.
Thanks in advance for your help.
Dave
dspaw is offline   Reply With Quote
Old 09-03-2016, 07:55 PM   #2
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Can you post a picture of your current switch? You can get oodles of three position switches.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 09-04-2016, 04:30 AM   #3
Mentor , Ohio
Gaucho Switch
That's one of the problems - I don't have a switch. The switch was removed during an earlier renovation = I just have the gaucho frame with the motor - and two wires coming out of the motor. I have confirmed that the motor works, and am trying to re-build the gaucho. I suppose I will just get an after market switch since an OEM one does not seem to be available.
Old 09-04-2016, 06:37 AM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I will post a picture for you later on the original switch location. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 09-04-2016, 08:14 AM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
As for switch replacement, maybe look at an automotive winch switch.
When my US Gear overdrive relay packed up, one of the mechanic commented that it looked and performed exactly the same as his winch relay, with an out/neutral/in position. Also my power chute on my snowblower has the same switch, hold the switch left, chute goes left; hold switch to right, chute goes right; let go of switch and the chute stops.
https://www.firgelliauto.com/product...and-sustaining
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-04-2016, 11:23 AM   #6
bobmiller1's Avatar
Cheers
Tony
You had to say the "S" word didn't you....SNOW BLOWER....must be a Canadian thing ! Listen, I have some questions for you regarding your overdrive unit, will PM you later tonight. Regards, Bob
Gaucho extension-any success stories?? Creampuff Cabinets, Counter Tops & Furnishings 29 10-14-2004 03:16 PM
Gaucho or couch bed John Greenlee Cabinets, Counter Tops & Furnishings 15 09-16-2004 08:10 PM
Poll: Dinette VS Gaucho... robertandjenni Interior Restoration Forum 18 06-26-2003 12:40 PM
Adults Sleeping on Gaucho..is it comfy? 71Overlander Our Community 11 06-23-2003 06:26 AM
Original Gaucho Foam-Measurements? 74Tradewind General Interior Topics 1 02-20-2003 07:31 AM
