Old 12-10-2007, 07:37 PM   #1
N2XBW's Avatar
BRADENTON, On The Picturesque and Sunny West Coast of Florida, , USA, PLANET EARTH, MILKY WAY, LOCAL GROUP, SPIRALING SLOWLY THROUGH THE UNIVERSE
Question GAS GAUGE / FUEL TANK QUESTION - P-30 Chassis
Fellow Alumilovers,
The GAS GUAGE on my '84 Excella 270 /P-30 GM Chassis is kaput. It perpetually shows "Empty" and the "Low Fuel" light is on as well. My guess as to the most likely culpret is a bad sending unit. [Though I will check the wires before the tank is dropped!]
The gas tank is a 60 gallon and I can find only replacement senders for 40 gallon tanks.
Now, I'm gonna GUESS that the 60g tank is the same as the 40g, only LONGER. Therefore a sender for a 40 would work in a 60.
Also the listing my parts guy found for the 40g tank sender shows one for the 30-P chassis WITHOUT FACTORY AIR CONDITIONING, but none WITH AIR. What could the differece possibly be between air conditioning or NOT at the gas tank?
Your constructiive advise is keenly sought!
Thanks in advance!
John N2XBW
THE LIME HOLLOW BOYS
These aren't the droids you're looking for.
You can go about your business.
Move along.
N2XBW is offline   Reply With Quote
Old 12-11-2007, 08:06 AM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I suggest you give these guys a call before you drop the tank. They know the Teleflex gauges, can tell you what is required, and have parts available if you can't find a local source
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 12-11-2007, 01:29 PM   #3
N2XBW's Avatar
Ummmm.........
Which guys would that be, Guy99?
<G>
John N2XBW
Move along.
Old 12-11-2007, 01:41 PM   #4
guy99's Avatar
Images: 16
Originally Posted by N2XBW
Ummmm.........
<G>
John N2XBW
Oops, sorry
Home Page
Old 12-11-2007, 04:07 PM   #5
N2XBW's Avatar
Gracias, Senior!
John N2XBW
Move along.
Old 12-11-2007, 04:54 PM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
N2XBW
Is that possibley a Ham Call? Just curious.
Roger
Mikethefixit is offline   Reply With Quote
Old 12-12-2007, 03:58 AM   #7
N2XBW's Avatar
Roger,
N2XBW is my ham call.
73 de John N2XBW
Move along.
Old 12-12-2007, 07:22 AM   #8
1977 27' Overlander
Trotwood , Ohio
Fine Business John
KA8LMQ here
73's John
Roger
Old 12-18-2007, 08:38 AM   #9
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
I think the sender wire is the problem, since the gauge shows perpetually full if it shorts out enroute to the dash.
Merry Christmas to both of you newly-discovered hams!
73 de KJ4JK
jking is offline   Reply With Quote
Tank level gauge. FreshAir Fresh Water Systems 2 07-13-2007 09:55 AM
Gauge Question - Please help if you can guy99 Mechanics Corner - Engines, Transmission & More... 12 04-19-2006 12:25 PM
Conflict between OPD Valve & "Fuel Gauge" ? femuse LP Gas, Piping, Tanks & Regulators 0 04-22-2003 11:15 AM
Propane tank gauge Jim Miller LP Gas, Piping, Tanks & Regulators 6 04-09-2003 04:25 PM
Dual Fuel Gas regulator thenewkid64 LP Gas, Piping, Tanks & Regulators 5 03-12-2003 02:26 PM
